    Problem Raspberry pi 3 + recalbox EXT4-fs error
    recalbox ext4-fs
    6
    13
    7768
    • DJMatrix-HU3
      DJMatrix-HU3 last edited by
      I recently bought a raspberry pi and 2 SD cards SanDisk Class 10 32GB
      Everything worked perfectly
      one day I accidentally exclude the files from the SHARE folder and upon restarting the recalbox I received the errors:
      alt text
      I formatted the sd card I reinstalled the recalbox image but I still get the same error ..
      so I used the second sd card I had bought and I installed the recalbox image worked perfectly however I had to format the sd card to install a recalbox image with included roms package and I received the same error on the second sd card
      I do not know what to do to solve the problem ....
      already tried to format with several different softwares = bad extra_isize error
      I tried to format on mac osx = bad extra_isize error
      format on a smartphone android = bad extra_isize error
      PLEASE NEED A SOLUTION THE SDS CARDS ARE NEW AND COSTLY COST ... THNAKS 😞
        voljega Banned @DJMatrix-HU3 last edited by
        @djmatrix-hu3 said in Problem Raspberry pi 3 + recalbox EXT4-fs error:
        And we don't know either and can't know at atll because to this is a modified version which isn't the official one, so there is and will be absolutely no support for it.
        Install the official version.
        DJMatrix-HU3 1 Reply Last reply Reply Quote 0
          Which means those prebuilt.images are just a stupid plague made by people who don't understand what they do ...
          • DJMatrix-HU3
            DJMatrix-HU3 @voljega last edited by DJMatrix-HU3
            @substring @voljega said in Problem Raspberry pi 3 + recalbox EXT4-fs error:
            I formatted the sd in the mac terminal using the command "sudo EraseDisk FAT32 RASPBIAN MBRPartition /dev/disk2"
            alt text
            I installed the original recalbox image and received the error:
            alt text
            after restarting raspberry pi:
            alt text
            I tried installing the recalbox by raspbian and also not succeeding
            alt text
            PLEASE HELP 😞
            my sd cards are new I do not understand why this is happening
              recalbox is not compatible with rpi3 B+
              https://forum.recalbox.com/topic/13200/raspberry-pi-3b-plus-compatible/63
              • DJMatrix-HU3
                DJMatrix-HU3 @acris last edited by
                @acris my model is B
                not B+
                  OyyoDams Staff @DJMatrix-HU3 last edited by
                  @djmatrix-hu3 Just use an official image to get support, not a bad prebuilt one.
                  • DJMatrix-HU3
                    DJMatrix-HU3 @OyyoDams last edited by
                    @oyyodams I'm having a problem with the official image
                      @djmatrix-hu3 what type of SD card do you have exactly ? (vendor, etc.)
                      Are you sure your image comes from http://archive.recalbox.com/ ?
                      • DJMatrix-HU3
                        @oyyodams YES image from http://archive.recalbox.com/
                        Sandisk 32GB Class 10
                        alt text
                        alt text
                        Substring ivwshane 2 Replies Last reply Reply Quote 0
                          Substring @DJMatrix-HU3 last edited by
                          @djmatrix-hu3 usng the img makes formatting useless. The partition table is also erased.
                          The only reasin left i see is either a.faulty sd, either a faulty sd reader on your computer. I don't think the pi3 could be to blame
                          • ivwshane
                            ivwshane @DJMatrix-HU3 last edited by
                            @djmatrix-hu3
                            There are a lot of fake SanDisk cards out there. Have tried testing the cards with a counterfeit program?
                            https://www.raymond.cc/blog/test-and-detect-fake-or-counterfeit-usb-flash-drives-bought-from-ebay-with-h2testw/
                            DJMatrix-HU3 1 Reply Last reply Reply Quote 1
                            • DJMatrix-HU3
                              DJMatrix-HU3 @ivwshane last edited by
                              @ivwshane
                              really the cards are fake that was the reason for the problem, I sent back to the seller to receive the refund .. Thanks 😄
