    Buttons are pressed without touching them!!
    GamePad/GPIO/USB encoder
    buttons are pressed touching them
    7
    50
    13918
    • saver
      saver @Substring last edited by
      @substring how do i continue to event 2 or 3? And sorry but i didn t understad your question. I use the xin mo set - 18buttons. I bought it from ultracabs while i was following orders from here http://www.instructables.com/id/2-Player-Bartop-Arcade-Machine-Powered-by-Pi/ . Ps. Thank you for your patience with me and for your answers and realy sorry for my awful english
        Substring @saver last edited by
        @saver use the recalbox webmanager to edit recalbox.conf and disable the gpio driver. Set controllers.gpio.enabled to 0
        saver 1 Reply Last reply Reply Quote 0
        • saver
          saver @Substring last edited by acris
          @substring i have this image to my sdcard https://www.youtube.com/watch?v=kklTCp8HZBo and i can t find to the menu the recalbox webmanager to edit recalbox.conf. I tried from the config text but i didn t find "controllers.gpio.enabled"
          I made two arcade cabinet with the same setup and i have this problem only in one of them. Do you thing that if i disable the gpio driver i will fix it?
            @saver i'm not doing any support for unofficial images
            saver 2 Replies Last reply Reply Quote 0
            • saver
              @substring i am really sory but i didn t know that it was unofficial. I just made a resaearch for a recalbox image 32 gb like my sd card. I am not so familiar with all those things. I ll try with the official way. Anyway thank you very much for your help.
                OyyoDams Staff @saver last edited by
                @saver The official image is here: https://archive.recalbox.com/
                • saver
                  saver @OyyoDams last edited by
                  @oyyodams thank you very much. I hope with the ofdicial image to solve the problem.
                  • saver
                    Hello again. I install the official recalbox image but i still have the same problem. Here is what is written to recalbox.conf. The gpio controllers are already set to 0. Do i have to put # in the beggining of the sentence?
                    ------------ D2 - GPIO Controllers ------------
                    GPIO Controllers
                    enable controllers on GPIO with mk_arcarde_joystick_rpi (0,1)
                    controllers.gpio.enabled=0
                    mk_gpio arguments, map=1 for one controller, map=1,2 for 2 (map=1,map=1,2)
                    controllers.gpio.args=map=1,2
                    NeeeeB 1 Reply Last reply Reply Quote 0
                    • NeeeeB
                      NeeeeB @saver last edited by
                      @saver Nope, no need to comment the line, it's set to 0 so it is disabled.
                      Vieux geek ^^
                      • saver
                        @substring can you please tell me if now there is something wrong with my setup. The only thing i haven t replaced yet is the screen. Here is my bartop cabinet ant the results of the new evtest
                        https://postimg.cc/gallery/16tfiq92g/31740cb1/
                          @saver can you run again evtest with device 1 instead of 0 ?
                          • saver
                            @substring here it is.
                            https://postimg.cc/image/rzwpj3q3b/b80aabbe/
                            Now the player 2 buttons are unplugged. I try to isolate the problem but u fortunately i can t
                              @saver nothing seems to happen on your xinmo. Do you still have ghost inputs if you unplug your xinmo ?
                              • saver
                                @substring when the problem began i had those inputs even with the xin mo unplugged. Now i haven t try it again. I have already replaced the whole xin mo set exept the buttons, the raspberry pi , the sd card and all the cables. The only thing i haven t replaced yet is the screen because i haven t a second one. But i still have the problem. And it begins after 2 or three hours or more after switching on the console and not from the beginning. I made a second bartop cabinet with the same setup for my brother with no problem at all. Mine bartop has the problem. I am so desperate!
                                  @saver you have to run evtest when the problem does happen, and run evtest on ech input device
                                  • saver
                                    @substring i tried yesterday to run evtest when the problem began again but i noticed that the pie was out of internret connection. Then i tried to connect to my wifi and i saw instead of my wifi key this https://postimg.cc/image/ilx9c1jkn/343a9b6e/.
                                    I didn t touch anything. I think that if i manage to put my wifi key and connect to my wifi i will solve the problem. But temporarily. Can you think what is going on now?
                                      @saver the wifi key is encrypted (hence enc:) for security purpose
                                      • saver
                                        @substring so i guess this is not the broblem?
                                          @saver nope. But why are you losing lan connection ?
                                          • saver
                                            @substring i realy don t know. But i have the same problem even without connection at all
                                            100.2k
