    Buttons are pressed without touching them!!
    GamePad/GPIO/USB encoder
    buttons are pressed touching them
    7
    50
    13917
    • saver
      saver @Substring last edited by
      @substring here is the evtes during the problem https://postimg.cc/gallery/2t129wh3w/b01e24f1/
      And still is writing and writing and writing
      • Dragu
        @saver
        Could you post a picture about your connections INSIDE the bartop, buttons and joysticks. Mass (-) connection needs to be connected in chain from one button to the next, otherway you risk HF disturbances. Same problème for switching power supply units near the mass cables. If they have no metallic case and are from the type to put on the table near a notebook, or in socket far away, together with parallel mass wires, deadly.
        Also it can just be a defect 5V power supply unit, because I read that it arrive after some time only. I would change this first. And take an 3A Aukru or Northpada 😉
        • saver
          saver last edited by
          Here is photos of my setup. I have built two identical bartop cabinets https://postimg.cc/gallery/20r8hezj0/026a7816/ with different screens one for me and one for my brother. Only mine has the problem. I replaced everything from my cabinet. Now the second player is unplugged. https://postimg.cc/gallery/10wc7yuzg/eff0777a/
          I have followed directions from here
          https://www.google.gr/amp/www.instructables.com/id/2-Player-Bartop-Arcade-Machine-Powered-by-Pi/%3Famp_page=true and here
          http://youtu.be/hpLp929pM4c
          Ps. I have my cabinet over my laptop and near my router. Is it a problem?
          • Dragu
            @saver
            Did you also change the power supply of your PI ? Apart you have very long wires everywhere. I would first unplug the openend wires on the Gpio and not stay them connected with pluged encoder. If not this makes antenna. Also better to squize the oversize wires (as you did with power supply) instead rolling them up. But if you tell that the problem occurs after some time only, power supply is a possibility. Anyway it should be a pure hardware problem .
              most probably a generic ground problem ?
              • saver
                I have changed everything. Pi, micro sd, encoder, joysticks, all the cables including the power supply of the pi. All except buttons and screen. Generally i made the two cabinets with exactly the same way and i have the problem only in mine. Substring what does "generic ground problem" means? And what is the conclusion of the evtest i attached?
                • Dragu
                  @saver
                  I have also see that you dig out the sound from jack. This must be a plug with 4 sections, like in the Wiki if not you short the composite video output, also on this jack. It may be not the base of your problems, but not healthy. Much better to dig out the sound from hdmi connector to the screen, with also better sound quality.
                  alt text
                  saver 1 Reply Last reply Reply Quote 0
                  • saver
                    saver @Dragu last edited by
                    @dragu i had the problem even with the jack unpluged. I put the cabinet to another place away from the internet router and laptop to see if this is the problem.
                    • saver
                      I think that the problem is finaly solved. The last 7-8 days i have removed my bartop cabinet and put it away from my wifi router and laptop. I don t know yet which of those two caused the hole problem. Anyway everything it s OK now. Thank you very much for your help and support. Thank youuuuuu!!!
                        Substring @saver last edited by
                        @saver glad you made it 🙂
                        100.2k
