    Recalbox 18.03.16 is out!
    Announcements
    recalbox 18.03.16 out
    23
    59
    47020
      Yo !
      New release today, I won't list the details here, but hurry and head over to the blog for the general info and here for more details :)!
      For impatient people, have a look at https://youtu.be/-TtzRFInKqc for the new features 🙂
      Edit: the video is not telling everything about the update, do read the blog 😉
      1 Reply Last reply Reply Quote 7
      • cazeysan
        cazeysan last edited by
        Wonderful, thank you !
        Viens par là, c'est pareil !
        • roman126
          roman126 last edited by roman126
          Thanks everyone.....looks amazing! can’t wait to try it out! And no more Xmas splash vid 😄
          Just waiting for my build to detect there is an update!
          Managed to update through Putty and ran the upgrade script manualy
          • nayok
            nayok last edited by
            Super, je mets à jour demain !
            Rpi 3 B+
            Recalbox 9.1
            Usb Storage
            USB Xin-Mo controller
            • korni
              korni last edited by
              Thanks for this great update and your hard work. For me today is Christmas and birthday together! 😉
              • lackyluuk
                @Substring and the whole team: Thank you for your hard work on this. I don't take this for granted!
                I am looking forward to try all the new features :))
                • alpermis
                  alpermis last edited by
                  Thank you for the new version. But I experience some bugs. The major one is when I quit a game screen resolution does not fix and stay as the game's.
                    Substring @alpermis last edited by
                    @alpermis great ! I need a support archive please
                    alpermis 1 Reply Last reply Reply Quote 0
                    • alpermis
                      alpermis @Substring last edited by
                      @substring I have no idea how to provide you that. Give me some info please.
                      Substring alpermis 2 Replies Last reply Reply Quote 0
                        @alpermis open a separate thread please. For the support archive, go to http://recalbox/help or http://recalbox.local/help if you're on mac/linux
                        • alpermis
                          alpermis @alpermis last edited by
                          @alpermis https://file.ac/cpM07Is-zEA/
                          • kos
                            kos last edited by
                            Не корректно отображаются буквы при выборе Русского языка.
                            Letters are displayed incorrectly when you select The Russian language.
                            voljega shaizen 2 Replies Last reply Reply Quote 2
                              voljega Banned @kos last edited by voljega
                              @Substring afeter update no rom is lauching anymore, on all systems (I'm using external HDD)
                              Launching the support script through manager doesn't work anymore, with following error :
                              Command failed: /recalbox/scripts/recalbox-support.sh /recalbox/share/saves/recalbox-support-bbda8044-2e84-2b07-68b4-0b6ecfec6ac6.tar.gz lspci: /sys/bus/pci/devices: No such file or directory /recalbox/scripts/recalbox-support.sh: line 53: aplay: command not found /recalbox/scripts/recalbox-support.sh: line 54: glxinfo: command not found /recalbox/scripts/recalbox-support.sh: line 55: xrandr: command not found /recalbox/scripts/recalbox-support.sh: line 100: /recalbox/share/saves/recalbox-support-bbda8044-2e84-2b07-68b4-0b6ecfec6ac6.tar.gz: Read-only file system tar: -: Cannot write: Broken pipe tar: Error is not recoverable: exiting now Reporting zip creation failed
                              Through command line, doesn't work too :
                              # cd ../../scripts/
                              # ./recalbox-support.sh
                              ./recalbox-support.sh: line 53: aplay: command not found
                              ./recalbox-support.sh: line 54: glxinfo: command not found
                              ./recalbox-support.sh: line 55: xrandr: command not found
                              ./recalbox-support.sh: line 100: /recalbox/share/saves/recalbox-support-20180317115448.tar.gz: Read-only file system
                              # cd ../share
                              # ../scripts/recalbox-support.sh
                              ../scripts/recalbox-support.sh: line 53: aplay: command not found
                              ../scripts/recalbox-support.sh: line 54: glxinfo: command not found
                              ../scripts/recalbox-support.sh: line 55: xrandr: command not found
                              ../scripts/recalbox-support.sh: line 100: /recalbox/share/saves/recalbox-support-20180317115520.tar.gz: Read-only file system
                              doesn't even work with mount -o remount, rw / !!!
                              Share must not well mounted, and after that got again a crash when shutting down fast, second one in two weeks, it never happened before...
                              • alpermis
                                Is there anyway to find previous release?
                                  Substring @voljega last edited by
                                  @voljega fab2ris has been streaming for 4h yesterday and very oftzn swapped between external and sd share, had no probs regarding roms
                                  I'll check tonight for the manager and support script
                                  • Gruute
                                    Gruute last edited by
                                    Encore merci pour cette nouvelle mise à jour. Je cherche à composer le thème parfait pour l'interface 🙂
                                    Le seul souci que je rencontre jusqu'à maintenant, c'est que, au bout de 4-5 changements (icone, couleurs, organisation du menu, etc.) et donc de switch à chaud, l'écran "veuillez patienter" se fige (et la musique saccade, quasiment jusqu'à en devenir muette). Du coup, je redémarre par l'accès web "recalbox/" plutôt que de booter comme une brute.
                                    • alpermis
                                      I can not download previous build here https://gitlab.com/recalbox/recalbox/tags. It says 404 not found 😞
                                      It was working perfect and now I have to reboot after each game change, because half of the content is out of the screen. I just want to install previous build but It seems I can't find it at all 😞
                                        OyyoDams Staff @Gruute last edited by
                                        @gruute
                                        1. This is an english thread! - C'est un sujet en anglais!
                                        2. Please open a new topic for support. - Merci d'ouvrir un nouveau sujet pour du support.
                                        Gruute 1 Reply Last reply Reply Quote 1
                                          voljega Banned @Substring last edited by
                                          @substring said in Recalbox 18.03.16 is out!:
                                          Yeah it's just the share which was mounted in ro. Everything seems resolved after repair + restart. But happened twice since previous updte compared to never before in two years
                                          • Gruute
                                            Gruute @OyyoDams last edited by
                                            @oyyodams Oups, sorry about that. I will do it right now !
