    Move files from Computer to microsd via Reader?
    move computer reader
    3529
    • userreddit
      userreddit last edited by
      I'm kind of fed up with how long it's taking to transfer small files over WIFI. Plus, I can't get WIFI to work consistently. Is there a way to transfer my ROMs directly by plugging my microsd into the card reader on my computer? I tried before, but the file system looked completely different than it did on WinSCP. I'm using Windows 10.
        voljega Banned @userreddit last edited by
        @userreddit No, not possible.
        You can use usb key as storage and then use that on your computer, it will be much faster and it's better anyway
        • userreddit
          @voljega Hmm, what about ethernet? I tried to plug my Pi3 into ethernet and it didn't work. Is there a way to force the Pi3 to use ethernet so that the transfer goes faster?
          userreddit voljega 2 Replies Last reply Reply Quote 0
          • userreddit
            userreddit @userreddit last edited by userreddit
            @voljega I will probably use a USB stick for some. However, I have a lot of multiplayer games that I would like to have my USB slots open for. Yes, I could use a powered hub, but I'm trying to keep this setup portable.
              @userreddit it should work on ethernet, debug your connection with your box
              userreddit 1 Reply Last reply Reply Quote 0
              • userreddit
                userreddit @voljega last edited by
                @voljega I'm not sure how to go about debugging it. I'm an absolute noob.
                  @userreddit look in the menu of EmulationStation if your pi gotvan ip adress and if it's only numbers
                  • userreddit
                    @voljega I mean, it shows my IP address if that's what you mean. There has to be a faster way to get the roms onto the microsd card.
                    voljega paradadf 2 Replies Last reply Reply Quote 0
                      @userreddit I meant with ethernet, not wifi !
                        paradadf Staff @userreddit last edited by
                        @userreddit read the forum and the wiki, please!
                        https://github.com/recalbox/recalbox-os/wiki/Copy-roms-from-a-Computer-to-the-SD-Card-using-an-USB-Stick-(or-External-Hard-Drive)-(EN)
                        Wirh your usb plugged in, you can use the file manager from within kodi as well and have an interface.
                        Another option could be to use a live cd with any linux distribution, like ubuntu.
