    Save highscore in FBA Literto
    highscore fba literto
    5772
    • iggy2
      iggy2 last edited by
      Since i upgrade the recalbox to latest the fba literto games don't save highscore.
      Is'nt this possible now or do i have to put highscore.dat someware else?
      Please help
      iggy2 1 Reply Last reply Reply Quote 0
      • iggy2
        iggy2 @iggy2 last edited by
        @iggy2 Hello could any one please help?......
        • barbudreadmon
          barbudreadmon last edited by
          There was a bug in the hiscore system of fba libretro, i fixed it ~10 days ago. I don't know what version of fba libretro the last release of recalbox is using.
          If you got any .hi files generated from a buggy version of fba libretro in the folder where you store the hiscore.dat, you must delete them.
          The file (hiscore.dat) is still needed under a fba subfolder of your retroarch system folder (which should be the one where you store bioses), recent releases of fba should support both old and new format of hiscore.dat.
          Libretro developper :
          • FBAlpha FBNeo (Arcade)
          • Kronos (Sega Saturn/ST-V)
          • YabaSanshiro (Sega Saturn)
          • iggy2
            Hello,
            is'nt the higscore.dat file placed here /recalbox/share/saves/fba_libretro/?
            Deleted al old files
            • barbudreadmon
              barbudreadmon @iggy2 last edited by
              @iggy2 definitely not
                Substring @barbudreadmon last edited by
                @barbudreadmon we're not using the standard RA paths in .config 😉 but i guess it should be with bios
                • barbudreadmon
                  barbudreadmon @Substring last edited by
                  @substring said in Save highscore in FBA Literto:
                  Yes, under a folder named fba, not fba_libretro, except if you symlinked fba_libretro to fba
                  • iggy2
                    Thanks for help, But still no luck....I deleted al old hiscore files then copy the highscore.dat to bios/fba then starts a game, end game and see a new hiscore file is generated in bios/fba, open it in wordpad and it looks good with the name i write for higscore. starts same game again but now al higscores are wrong,,,,can look like this 123&5?i83672917 so something happens when it loads up again.....shouldent the hichscore file thats made from the game end up in the save folder?......tryed both old and new higscore.dat but resolt is the same...please help....thanks
                    • barbudreadmon
                      @iggy2 As i told in my first post, you have the old fba libretro version with the bug, you must update it.
                      • iggy2
                        To update you replace the FB Alpha v0.2.97.42 DAT file?
                        • barbudreadmon
                          @iggy2 You don't update a software by replacing a text file. I don't know how you update cores on recalbox, perhaps through emulationstation or retroarch's menu ? You should ask someone knowledgable about it like @Substring
                            Recompile the core yourself, or wait for a recalbox update
                            • 0zzy
                              0zzy last edited by
                              Hi, i have the last recalbox imgage on my pi3 and also i can't save highscore, why?
                                Because it s a bug.
                                Fba libretro will upgrade soon in recalbox
                                • 0zzy
                                  0zzy last edited by
                                  thanks acris, i tought it was already fixed
