    [SOFT] Arrm (Another Recalbox Roms Manager)
    Community projects
    another arrm manager recalbox roms
    35
    251
    193596
    • nexusone13
      nexusone13 @jorgemagana last edited by
      @jorgemagana Hi,
      In your example, The boxart (wor) is the one displayed on your screenshot.
      On 'screenscraper' there is another boxart available boxart (SS) : (SS) media are specifically created by 'screenscraper', but are not 'official' if I understood correctly.
      I'm working on a new release with a ' Force SS media' checkbox (another one 🙂 ) to force ARRM to grab (SS) media. I'll send you a beta version on pvt chat.
      For now you can check the 'Box 3D' to display a boxart which look nicer 🙂
      ARRM (Another Gamelist, Roms manager, and Scraper for Recalbox, Batocera, Retropie) : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager
      Wiki ARRM: http://www.jujuvincebros.fr/wiki/arrm/
      Discord: https://discord.gg/p7QsBTS
      jorgemagana 1 Reply Last reply Reply Quote 0
      • jorgemagana
        jorgemagana @nexusone13 last edited by jorgemagana
        @nexusone13 Thanks for your answer, I found a solution doing this:
        1. Select "Show mix model"
        2. Select "Edit XML file"
        3. Delete "boxart" in Data- Element-Layer4
        I got the "arcade profile" image!
        nexusone13 1 Reply Last reply Reply Quote 1
        • nexusone13
          @jorgemagana Well done 🙂
          I thought you still wanted the boxart. I misunderstood 🙂
          I advise you to create your own mix, by copying the directory of this mix under another name and editing as you did the data of the xml, and especially by changing the name of the mix in this tag <name>Arcade Profile</name>. Because during an uninstall of the application to install a new version, the original mixes are replaced, but not the mixes created by the user.
          • jorgemagana
            @nexusone13 ok, thanks!
            • nexusone13
              Hi All
              New version available : 1.7.5.2 (05/14/2019)
              • Typing on a letter in the database (if sorted in alphabetical order), positions the index on the first name of game found starting with this letter (request from Zing forum Recalbox)
              • Following the deletion of Rom, the index is positioned on the next element and does not come back to the beginning of the list (request from Zing forum Recalbox)
              • System Sorting / The sorting of the es_systems.cfg is now possible on Retropie.
              • Added a 'retropie' checkbox to launch the 'Stop and Reboot EmulationStation' scripts, to manage the specificities of overlays Retropie, and the SystemSorter specified to Retropie (request of morenr1 on the retropie forum)
              • Can retrieve and create overlays configuration files for Recalbox, Batocera and Retropie
              • Added a 'filter duplicate games' button on the Game name or on the file name which allows to filter the Roms whose name of the game or the file name (without extension) appears on other Roms. Example for ARRM: 1943 and 1943kai will be listed as duplicated because 1943 appears in 1943kai (thanks to Zing for testing)
              • Added a 'Screen Title' checkbox to get the game's Screen Title instead of the screenshot. If checked, it can be used as a Screenshot or in the Mix. (request of ExarKunIv on Retropie forum)
              • Add a "Europe Media" checkbox to retrieve Europe's special media if present. (Lucinda's request on recalbox forum)
              • Added an 'SS Media' checkbox to force SS media recovery (specifically created by Screenscraper)
              • Added a checkbox 'add country' that adds the country, at the end of the game name, if this information is present in the name of the rom file.
                  If the MD5 of the game is filled in, ARRM can retrieve on screenscraper the information of the Country of Rom, during a scrap or during a 'Verif name via MD5' (API V2 only)). With the MD5 the country information will be more complete.
              • Tag Marquee and Video are now written in the gamelist.xml, in order to use these features in Batocera v5.21 and Retropie.
              • Textbox to indicate a way for the videos (request of morenr1 forum retropie)
              • If the mode '4 images' is not selected, only the tags 'image', 'video' and 'marquee' are now saved (previously boxart, screenshot, marquee, mix, cartridge were saved in the gamelist.xml) (request from kevinnash forum Recalbox)
              • His played (Back to the Future locomotive) at the end of a scrap. The sound can be activated via a checkbox 'Its end scrap' in the tab 'General options' (request of Kevinnash forum Recalbox).
              • Line breaks and tabs are taken into account in the textbox 'description'. (bug brought back by Zing)
              • Backup paths for overlay images, overlay configuration files and input_overlay 'can be set via a config file
              • Fixed inconsistencies in media search (by country) using API v2
              • Change the path to recover the original es_systems.cfg file on Batocera v5.21
              • Fixed a bug when validating a nonexistent screenscraper account
              • Added additional information about ScreenScraper user account (screenscraper login module)
              • Remove redundant 'add disk / tape / side' button with 'Check Roms' which already applies the following checkboxes: 'Clean Name', 'Add Disk', 'Keep Rom Name', 'Add Country'
              • Fixed bug on auto-assignment of template with 'Recompose image'
              • Fixed various bugs
              • Adding an Amstrad GX4000 template
              ARRM Wiki (with some practical cases) : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=start-en
              Download Link : http://jujuvincebros.fr/telechargements2/file/10-arrm-another-recalbox-roms-manager use 'Mirror Link1' if you get an 'Invalid Token' error message.
              • appa84
                appa84 last edited by
                Arrm 1.7.5.2 Downloaded. The program does not open. What should I do.
                nexusone13 2 Replies Last reply Reply Quote 0
                • nexusone13
                  nexusone13 @appa84 last edited by
                  @appa84 Hi sent you a file in pvt chat
                  nexusone13 1 Reply Last reply Reply Quote 0
                  • nexusone13
                    nexusone13 @nexusone13 last edited by nexusone13
                    For those having trouble launching the application, here is a workaround (have to fix that soon). Grab this file (registry key) i found the bug, some trouble creating registry key. Get this one : http://dl.free.fr/nHWkEIygo
                    unzip it and register .reg file, then launch app.. Some trouble with the new version creating the reg key. I'll work on that very soon and release a bug free version.
                    Only occurs with new users
                    • nexusone13
                      @appa84 bug fixed. Online application updated. You can download it again
                      • nexusone13
                        Hi All
                        New version available : 1.7.5.3 (05/17/2019)
                        • Fixed the bug that prevented the v 1.7.5.2 application from getting started with new users.
                        • Added a splashScreen at launch.
                        • nexusone13
                          Hi All
                          1.7.6.5 (06/10/2019)
                          • Added translation of the interface in Chinese (thank you Lyon00)
                          1.7.6.3 (06/10/2019)
                          • The logs are centralized in a subdirectory (logs_arrm) of the selected system.
                          • When 'Keep rom name' is checked, 'Add disk' & 'clean name' are disabled
                          • Database update: rom / core arcade compatibility (BestArcade4Recalbox-19-05-09).
                          • Add in the tools tab of a textbox to modify the compression parameters of pngequant (request of Ismaily T. M. on the JujuVinceBros facebook page)
                          • Added in the tools tab a button 'Update Best Arcade Core' to update the database with the best core arcade based games. Uses the files 'fba_libretro.csv', 'mame2003.csv', 'mame2010.csv' from BestArcade4Recalbox-19-05-09 list: https://docs.google.com/spreadsheets/d/1F5tBguhRxpj1AQcnDWF6AVSx4av_Gm3cDQedQB7IECk/edit?usp=sharing. These files are located in '%appdata%\nexouille soft\arrm\database'. The 'Update Core' button uses this database.
                          1.7.6.1
                          • When adding disk taking into account of [Part x of x] in the file name
                          • When adding disk taking into account references memory sizes (16k) (48k) (128k). I use it for my collection of Roms Zx Spectrum which proposed 3 sizes different memories and therefore slightly different Roms.
                          • Taking into account the video during a recompose image if the video file is present (Jay's request)
                          • Ability to add a video manually to a Rom via the 'Video' button in the game card (Jay's request)
                          • Ability to stop the various treatments applied to selected Roms.
                          • Ability to modify the timeout value on web requests (via the 'Tools' tab). Increase the value when scrap server is overloaded.
                          • Use the 32bits or 64bits version of pngequant (compressor PNG) depending on your environment.
                          • When recovering Video only, '4 images' mode does not need to be activated.
                          • Ability to recover the 'cartridge' as the default image.
                          • When launching a scrap with overlay, the previous file "missing_overlays% SYSTEM% .txt" is saved with the current date.
                          • Added the SNES CD template
                          1.7.5.4 (05/18/2019)
                          • Fixed a bug that crashed the application when duplicate search returned too many items.
                          • Fixed bug when searching with keywords and with filters
                          • Changed path for systems overlay path for recalbox in 'overlays_path.txt' file : /recalbox/share/system/configs/retroarch/overlays changed to /recalbox/share/system/.config/retroarch/overlays
                          • nexusone13
                            Hi All,
                            New version of ARRM available :
                            1.7.7.0 (10/05/2019)
                            • Automatic association of templates by system via the template selection menu. You no longer need to edit the template_association.txt file manually.
                                 Operating mode: select a single system, then click on 'Show Mix Model' to select the desired template, then confirm.
                                 The system / template association will be saved in the template_association.txt file
                                 If you wish to modify the default template: Do not select any system and click on 'Choose Mix Template', then confirm.
                            • Added several templates: Famicom, DOS (profile), MSX TurboR, Othello Multivision, Sega Mark III, Sharp X1, Spectravideo, Super Famicom, TurboGrafX, Box Marquee Cartridge and Box cartridge
                            • fix bug when filtering game title containing a simple quote (thx virus-man)
                            • Update systems for Recalbox / Batocera
                            • update of the core / emulator for Batocera / Recalbox
                            • nexusone13
                              Hi All,
                              1.7.7.5 (10/31/2019)
                              • Added templates for Myst's Next_Pixel 1.3 theme for Recalbox (https://samystudio.github.io/es-theme-next-pixel/). See Wiki : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=templates_available_en
                              • Added Rom file renaming button with game name (Ninjaw request)
                              • Add a video preview of the snap video if present (the sound is deliberately cut) Right click on the video to access full screen, play / pause, etc ...
                              • Added video button that appears in the game card when a video is present. By clicking, it opens the media player associated with the extension of the video. (Ninjaw asks)
                              • Added a checkbox in the 'Tools' panel to compress video with handbrake whose encoding parameters are modifiable in 'Handbreak parameters', making them compatible with OMX player for Retropie (Morenr1 request via mail). See Wiki : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=settings-fr#tools
                              • The template file allows to manage differently the display of boxarts according to their format (portrait, landscape (style N64), CD). See the Next_Pixel templates for an example.
                              mYSt 1 Reply Last reply Reply Quote 1
                              • mYSt
                                mYSt Theme moderator @nexusone13 last edited by
                                @nexusone13 Hello!
                                Bonne nouvelle pour le thème Next Pixel puisque plusieurs personnes me l'on demandé. Je n'ai pas encore eu l'occassion d'utiliser ARRM et du coup c'est intégrer directement dans l'outil? y'a il possibilité de charger un mix externe, je peux éventuellement créer les mix adapté pour ARRM de mon coté, à discuter ensemble ce qui est le mieux.
                                • nexusone13
                                  nexusone13 @mYSt last edited by nexusone13
                                  @myst j'ai crée manuellement les mix appropriés listés dans ton fichier next_pixel.xml. Je reprends ton tes .png et je fais un petit .xml perso interprétable par arrm (j'ai fait divers templates pour ARRM visible ici : http://www.jujuvincebros.fr/wiki/arrm/doku.php?id=templates_available_fr). Si jamais tu sors d'autres mix, n'hésite pas à me le faire savoir que je crée le .xml associé. Et encore félicitations pour ton superbe thème.
                                  lecureuil38 1 Reply Last reply Reply Quote 0
                                  • ViRuS-MaN
                                    ViRuS-MaN last edited by
                                    next pixel et pour moi le meilleur thème pour revalbox , aucun autre thème n a été aussi beau pour moi , franchement tu a fait un thème qui tue et tous mes potes sont étonné de voir mon odroid xu4 avec une aussi belle interface
                                    mYSt 1 Reply Last reply Reply Quote 0
                                    • mYSt
                                      mYSt Theme moderator @ViRuS-MaN last edited by
                                      @virus-man merci ça fait plaisir!
                                      @nexusone13 ok alors du coup tu utilises la version 1080p du mix et ça ira très bien pour les pc et odroid mais ceux qui ont un raspberry vont rapidement se plaindre de pb mémoire je pense. Y a t'il une option dans ARRM pour resizre les mix généré? sinon il faudra décliner le mix pour chaque package, en fait actuellement suivant le package que tu télécharges 1080/720/480/crt/crt_small le xml du mix est adapté à sa taille.
                                      A voir si on peut trouver une solution sur ce point Ă  l'avenir.
                                      • lecureuil38
                                        lecureuil38 @nexusone13 last edited by lecureuil38
                                        @nexusone13 :
                                        je viens de tester en suivant tes indications pour le template ( copier +coller) mais les snap video ne fonctionne pas pour moi.
                                        ps: super boulot a tous les 2, bosser en colab pour nous pondre un RB d'enfer!
                                        Raspberry Pi 3b +
                                        Aukru 5V 3A
                                        boitier NES transformé
                                        Micro SD Sandisk Ultra 16 Go
                                        disque usb2 500Go
                                        8bitdo SF30 Pro
                                        RPi4 4G° + HDD 2T° ( usb3)
                                        PC_x64 I5 8G° Intel HD3000 / ati HD5460
                                        realisation nes+recalbox : https://www.thingiverse.com/thing:4152784
                                        • nexusone13
                                          nexusone13 @lecureuil38 last edited by
                                          Bonjour @lecureuil38
                                          As-tu bien coché la case 'Récupérer la video (Video Tag)' dans l'onglet 'Images options' lorsque tu as scrapé ?
                                          • nexusone13
                                            @myst les mix générés font un peu moins de 300 ko en 1260x1080
                                            101.0k
