    Solved SCUMMVM - path de sauvegardes
    scummvm path sauvegardes
    2541
    • unik314r
      unik314r last edited by
      J'ai cherché un peu sur le forum, en fr en en, mais je n'ai pas trouvé: sauriez-vous me dire où sont stockés les fichiers de sauvegarde pour SCUMMVM?
      je n'ai rien dans saves:
      # ll -a /recalbox/share/saves/scummvm/
      total 8
      drwxrwxrwx 2 root root 4.0K Feb 26 2017 .
      drwxrwxrwx 31 root root 4.0K Nov 6 23:10 ..
      Et rien non plus comme fichiers créés dans les dossiers d'install des jeux.
      Merci.
      • unik314r
        unik314r last edited by unik314r
        c'est ok:
        find . -type f -exec ls -ltrha {} ; | grep "Dec 11"
        -rw------- 1 root root 201.2K Dec 11 19:34 ./roms/scummvm/downloaded_images/sword2-image.jpg
        -rw-r--r-- 1 root root 3.9K Dec 11 23:21 ./roms/scummvm/gamelist.xml
        -rw-r--r-- 1 root root 763.2K Dec 11 23:21 ./roms/gb/gamelist.xml
        -rw-r--r-- 1 root root 127.2K Dec 11 23:21 ./roms/mastersystem/gamelist.xml
        -rw-r--r-- 1 root root 248.0K Dec 11 23:21 ./roms/mame/gamelist.xml
        -rw-r--r-- 1 root root 151.4K Dec 11 23:21 ./roms/gbc/gamelist.xml
        -rw-r--r-- 1 root root 39.8K Dec 11 23:21 ./roms/gw/gamelist.xml
        -rw-r--r-- 1 root root 180 Dec 11 23:21 ./roms/dos/gamelist.xml
        -rw-r--r-- 1 root root 180.6K Dec 11 23:21 ./roms/nes/gamelist.xml
        -rw-r--r-- 1 root root 248.1K Dec 11 23:21 ./roms/snes/gamelist.xml
        -rw-r--r-- 1 root root 35 Dec 11 23:21 ./roms/prboom/gamelist.xml
        -rw-r--r-- 1 root root 187 Dec 11 22:21 ./system/.config/scummvm/scummvm.ini
        -rw-r--r-- 1 root root 763 Dec 11 22:51 ./system/.local/share/scummvm/saves/sword2.000
        -rw-r--r-- 1 root root 526 Dec 11 22:51 ./system/logs/es_launch_stderr.log
        -rw-r--r-- 1 root root 145 Dec 11 23:21 ./system/logs/virtualgamepads.log.old
        -rw-r--r-- 1 root root 818 Dec 11 22:52 ./system/logs/es_launch_stdout.log
        -rw-r--r-- 1 root root 1.9K Dec 11 23:21 ./system/configs/asound.state
        -rw-r--r-- 1 root root 1.0K Dec 11 22:51 ./system/.cache/scummvm/logs/scummvm.log
        -rw------- 1 root root 11.0K Dec 11 23:21 ./system/.bash_history
        -rwx--x--x 1 root root 534 Dec 11 23:21 ./scripts_perso/gamelist.xml
        Marrant que ce ne soit pas dans /recalbox/share/saves/ comme pour les autres...
        Je suppose que c'est précisé qqpart dans la doc?
          Substring @unik314r last edited by
          @unik314r non pas précisé dans la doc, et sûrement qu'il faut patcher l'émulateur. Mais n'ayant que 2 bras et un temps de plus en plus limité ...
          unik314r 1 Reply Last reply Reply Quote 0
          • unik314r
            unik314r @Substring last edited by
            @substring ok, je pensais que j'avais pas cherché assez 🙂
            Perso, tant que j'ai ma solution, ça me va, je ne suis pas du style à attendre ce genre de correctifs avec impatience: je sais que ce genre de projets prend énormément de temps (surtout si il faut s'occuper du support forum etc...)
            Par contre, si il y a un endroit où je peux indiquer qu'il pourrait y avoir un patch à prendre en compte, fais-le moi savoir (au cas où)
            Bref, bon courage, continuez le bon boulot 😉
              @unik314r il faudrait vori avec @lackyluuk (lui parler en anglais, il est allemand) vu qu'il travaille sur les wikis de chaque systeme
              • lmerckx
                lmerckx last edited by
                Je réagis seulement ... chez moi, les sauvegardes sont bien dans /recalbox/share/saves/scummvm.
                Je viens de retester (des fois que la dernière mise à jour serait en cause) mais je parviens toujours à charger mes anciennes sauvegardes et en créer des nouvelles.
                Je n'ai rien dans system/.scummvm, à part les logs.
                De plus, le path de sauvegarde est passé à ScummVM en paramètre au moment du démarrage.
                Tu n'as rien dans system/.scummvmrc qui pourrait modifier le comportement par défaut ?
                Recalbox 9.1 on RPI 4, SSD 250Gb, 2 Logitech F710, Nespi4case
                Contributions for DosBox, ScummVM, ResidualVM, Daphne (Hypseus)
