    .srm not loading in snes
    Emulator Arcade/PC/Console
    srm loading snes
    • Steven C Janocha
      Steven C Janocha last edited by
      I am trying to move a .srm from a emulator i used to play Super Mario World to the Recalbox i just put together i put the Super Mario World(USA).srm file into RECALBOX/share/saves/snes. I restart my RECALBOX then go into game and the .srm does not load. Am i doing something wrong here with how i am supposed to get this done. Thank you
        OyyoDams Staff @Steven C Janocha last edited by
        @steven-c-janocha Hi,
        The .srm might be incompatible, are you sure it has been created with the same, compatible emulator ?
        • Steven C Janocha
          That i do not know i did not that would be a issue so i need to figure out how to make it compatible if i am going to get it to work.
            paradadf Staff @Steven C Janocha last edited by
            @steven-c-janocha enter the same a save it. Check if the name of that save is the same as you got from the other emulator.
