    V3.3.0 beta testers needed – besoin de beta testeurs
    v3.3.0 beta testers needed testeurs
    78
    401
    305038
    • guzilli
      guzilli last edited by
      Is Neo Geo CD supportet yet? would be a nice addition 😄
      • jujuforce
        jujuforce last edited by
        You can't. You need a keyboard for N64 at this time.   Also why the hell would you play N64 with a snes gamepad ?
        • colganfew
          colganfew last edited by
          Hi! Same problem in Beta 8. I’m having problems with bluetooth, use an Asus USB-BT400 Bluetooth 4.0 and raspberry 2. I have to remove it and put it on hot to connect the PS3 controls. Regards.
          • colganfew
            Hello. In some games FBA LIBRETRO I can not add credits, the emulator appears to ignore. Tested with PS3 controller and WII classic with Mayflash adapter. This problem is in beta 7 and 8. Regards.
            • digitaLumberjack
              It's a well know issue @ColganFew , you should use a button like L3 ou R3 for your hotkey
              • colganfew
                Thanks @digitalLumberjack !!! I did not know that!
                • ivwshane
                  ivwshane last edited by
                  On beta 8, I edited (using winscp text editor) the cfg file to use snes9x core, rebooted, and it doesn't look like it's using snes9x. In 3.2.11 with the default configuration, using an xbox 360 wireless controller I had the option to use the d-pad or the analog stick. On beta 8 the d-pad doesn't work (I've only tested on snes).
                  • actarus1973
                    actarus1973 last edited by
                    fba_libretro tourne avec les roms FBA v0.2.97.36, et je les ai trouver plus facilement que les roms mame 0.161 Même si je n’ai pas testé les 3750 roms, j’ai rencontré très peu de roms qui ne marchait pas ! Je n’ai pas rencontré de problème de son dans les Knights of Valour Certain tourne au ralentie (In The Hunt, Gun Force II) Le bouton L3 permet enfin d’accéder au dip switch (vies, difficultés,…) mais que pour les jeux capcom pour l’instant Les jeux neogeo aussi tourne mieux dans le dossier fba_libretro (Metal Slug 5, Samurai Shodown V Special) Dans le dossier neogeo c’est même roms tourne sans le son, et quand je change l’émulateur dans recalbox.conf je n’ai plus accès au réseau et plus aucun jeux ne se lance, obliger de formater la carte SD La v3.3.0-beta-8 ne reconnait pas ma manette xbox 360 filaire, testé que sur fba_libretro
                    • Wapata
                      Wapata last edited by
                      Cette manette: http://www.ebay.fr/itm/131287093519 Fonctionne très bien dans les menus, mais on ne peut en configurer que deux et pas quatre (la manette trois est une et la quatre est trois). Par contre... Rien de rien dans les jeux. Cela ne fonctionne pas.
                      • digitaLumberjack
                        tu peux essayer de forcer le driver sdl2 pour voir si ca change quelque chose : <span style="font-family: Consolas, 'Liberation Mono', Menlo, Courier, monospace; font-size: 13.6000003814697px; line-height: inherit; background-color: transparent;">global.inputdriver=auto dans recalbox.conf</span>
                        • ivwshane
                          Is there a reason why the d-pad on an xbox 360 controller doesn't work in games? I've tried using the default driver as well as uncommenting the other driver in the cfg file.   Also I still don't understand why I can't get snes9x to be the default snes emulator. Editing the cfg file works for other settings but pocketsnes continues to be the emulator used despite specifying snes9x_next as the core to use. The new cfg file isn't as clear as the old one so it's a possibility that I am doing something wrong.
                            Can you upload your recalbox.conf on pastebin please? And what kind of xbox dongle are you using? An official or a chinese copy?
                            • ivwshane
                              When using a wireless xbox 360 controller and a wired xbox one controller, both work fine in ES but when in an emulator on the 360 controller works. If I boot with out the 360 controller the xbox one controller will then work in the game. I've tried specifying what controllers to use in ES but it had no effect when using the 360 & Xbox one controller at the same time. The same issues also apply when using a ps4 controller instead of an xbox one.   The d-pad on any of the controllers no longer work in any emulators.
                              • ivwshane
                                I thought I was using an official adapter but now that I look at it I don't see any microsoft markings on it:|   I've never used paste bin, so what options do I need to choose?
                                • ivwshane
                                  Here is the paste bin link: http://pastebin.com/YRRgTwfA
                                  • digitaLumberjack
                                    How do you know it's not the new core ? Did you pop up the retroarch menu (HOTKEY + B) and verified the core used (displayed at the bottom of the screen i think)
                                    • ivwshane
                                      Yep, and it still shows pocketsnes. I've changed it without issue on 3.2.11 (after I learned to use a proper text editor).   Where are alternative cores stored? Can I change it through the GUI in retroarch?
                                      • Wapata
                                        En parlant de bon éditeur de texte, si bloc note est à faire, word pas qui est sur windows depuis au moins seven est il suffisamment bien foutu pour pas mettre le fichier en carafe ? Que ce passe t il si le fichier de configuration est corrompu ?
                                          D'après les retours des utilisateurs windows sur le forum, il est conseillé d'utiliser Notepad++. Après pour être tranquille, le mieux est encore de passer en ssh et d'utiliser l'éditeur nano. nano /recalbox/share/system/recalbox.conf puis modif ctrl+x pour quitter et y pour valider la sauvegarde.
                                          • digitaLumberjack
                                            Oui notepad ++ est vraiment conseillé. Il fonctionne nikel.
                                            100.6k
