    V3.3.0 beta testers needed – besoin de beta testeurs
    v3.3.0 beta testers needed testeurs
    78
    401
    305191
    • nickdj
      nickdj last edited by
      Using Beta 17 I'm not getting any sound with N64.     (removed comment about Wi-Fi not working.  It was just taking a long time to connect automatically.)
      RPi 2 Not overclocked Edimax EW-7811UN LogiLink BT0007A USB bluetooth V2.1 PS3 Controller RecalBox v3.2.8
      • karuzo
        karuzo last edited by
        Hello, after update to beta17 Kodi is not working proper. In the right corner next to the clock a red dot is flashing? I watch Youtube videos with Kodi but after Update not one video is playing fluent anymore? It is just stuttering like the connection is bad but it is not. Any ideas?
        • daveheart
          daveheart last edited by
          Bonjour,   Amateur de retrogaming et ayant eu énormément de pad entre mes mains, quoi dire, mis à part, un grand "BRAVO" aux développeurs. C'est du très beau boulot! Site excellent, nul besoin de chercher aux quatre coins d'internet. C'est très plaisant. Communauté, à priori, réactive d'après ce que je lis sur le forum. Vous pouvez me compter parmi les vôtres pour mon soutien et mes tests si besoin. Bonne continuation pour la suite que j'attends avec engouement. PS : J'ai trouvé comment je pouvais participer, indirectement, au projet 😉
          Pi 0w caméra/motion
          Pi 0 2w
          Pi 2 b Recalbox v7 / bartop / test
          Pi 3 b+ PINN / RaspioOs32 / Recalbox v8
          Pi 4 b PINN / RaspioOs 32 / LineageOs 18 / Recalbox v8
          • karuzo
            Hello again, To the problem with Kodi after update to beta17. I done a fresh reinstall and after install, Kodi worked as it should, but after installing Mausberry script to shutdown, the red dot in the right corner next to the clock in kodi appears again and is flashing like hell ;-). It is something with the sound.
            • tuxophil
              tuxophil last edited by
              Hi, I also had the red mute icon flickering next to the clock in the top right screen corner. I tracked it down to gamepad support for Kodi. In my case, the left trigger button of my Logitech F710 was getting mapped to the mute button, just like the analog sticks are mapped to volume control. I was able to work around the problem by either a) not mapping analog controls at all (I don't need them for SNES gaming) or b) entirely disabling Kodi's gamepad control functionality. (It's nice to have, but I'd rather have HDMI-CEC for emulationstation :-)) Anyway, this could probably be fixed by a different default setup for Kodi.   Here are some other problems I've encountered with beta17 (the first beta I've tried): - most of the time Kodi can't set the "watched" tag. (This may be related to my using a restored config/library through the Backup add-on) - can't use my second controller at all (also an F710): emulationstation shows 2 detected gamepads, but the 2nd one can't be configured. - neither controller is working in SNES games (at least that's the case for the builtin "Classic Kong"); the 1st one is working for navigating ES's menus, though. I'm going back to 3.2.11 for the time being. I'm really looking forward to the next stable version. Recalbox is simply great: one OS for Kodi and gaming. 🙂
              • digitaLumberjack
                Hi @tuxophil, you may have to switch the driver in recalbox.conf to sdl2 global.inputdriver=sdl2 in place of auto. If it works, can you give me the /root/.emulationstation/es_input.cfg file in order to set the sdl2 driver by default for your controller ?
                • tuxophil
                  Hi @digitalLumberjack, Thanks for your feedback! I'm currently short on sdcards, but I will check your proposed modification in a few days. (Santa's bringing some more sdcards ;-))
                  • ivwshane
                    ivwshane last edited by
                    With Beta 17 kodi is messed up. I get the flashing red speaker as well. Disabling joystick support stops the flashing but it's still muted and pressing f8 doesn't unmute it nor does increasing the volume.   N64, is broken again, I get sound but no video.
                    • poukin
                      poukin last edited by
                      Bonjour tout le monde, Déjà merci à Digital Lumber Jack pour ce super projet. J'ai un souci avec Kodi sur la beta 17 ; impossible d'aller à droite dans les menus, que ce soit avec Yatse ou avec le pad, une idée ?
                      • kromignon
                        kromignon last edited by
                        Hello tout le monde, je ne sais pas si c'est le bon endroit pour poser ma question, mais il faut bien se lancer quelque part 😉 Je trouve le projet RecalBox super sympa, mais j'aimerai plutôt le faire fonctionner sur un autre HW que la RPi 1 ou 2. Moi je dispose d'une Wandboard (iMX6 Quad-core). Comme RecalBox est basé sur BuildRoot et que celui-ci est capable de compiler un système pour iMX6, la partie système ne devrait pas poser trop de soucis... J'ai également déjà "zyeuté" du coté de chez Lakka, mais la combinaison avec Kodi me plaît beaucoup 🙂 Des conseils pour m'aider dans mon périple?
                        • rudyprome
                          rudyprome last edited by
                          Salut, je viens de me rendre compte que depuis la dernière Beta, Mame et FBA ne lance plus les jeux. Retour direct au menu d'EmulationStation. J'ai tenté de repartir sur une fresh install c'est pareil. Avez-vous fait de modifs à ce niveau là ?
                            Hello, au cours des différentes bêtas, il y a eu des updates des cores mame/fba. Du coup les romset ont evolués : - Mame : 0.37b5 -> 0.78 - FBA : 0.2.97.36 -> 0.2.97.37 Plus d'informations : https://github.com/recalbox/recalbox-os/wiki/L'arcade-facile-sur-Recalbox-(FR) https://github.com/recalbox/recalbox-os/wiki/L'arcade-avancée-sur-Recalbox-(FR)
                            • rudyprome
                              ah ok merci ! Je vais changer mes romsets alors. 🙂
                                voljega Banned last edited by
                                Hello étant donné qu'il reste que deux bugs sur la milestone de la 3.3.0 dont un qui semble corrigé et que tous les devs actuels ont l'air d'avoir lieu sur la alpha de la 4.0, quand peut on espérer la 3.3.0 finale ou une RC1 ? (non non je ne regarde pas le github tous les jours)
                                • alterlibriste
                                  alterlibriste last edited by
                                  Bonjour, Je suis en train de tester la dernière beta de la 3.3 sur un Raspberry Pi 1 Model B Pour l'overclocking en mode Turbo, lorsque je redémarrais, l'interface se bloquait au bout de quelques secondes, je suis allé voir dans le config de noobs au démarrage et j'ai vu que la SDRAM était à 500 au lieu des 600 préconisés avec ce mode, en modifiant, ça marche. Par contre, après quelques minutes de jeu sur plusieurs que j'ai testé, j'ai un plantage comme si le RPi s'arrêtait, est-ce que cela peut être dû à une surchauffe ?
                                  • mamadoo
                                    mamadoo last edited by
                                    Salut,   Sur la 3.3.3, que ce soit sur Pi 1 B ou Pi 2, Kodi est totalement bugué, vous aussi ? - Signe "son coupé" rouge qui clignote en haut à droite - Lancement d'un film le passe en accéléré - Impossible de quitter kodi, aucune fonction du menu éteindre/redémarrer/sortir ne fonctionne J'utilise un PAD 360 Merci
                                      @mamadoo Active le pilote xboxdrv dans le fichier recalbox.conf
                                      • darkam
                                        darkam last edited by
                                        Hello, Je viens de passer sous la 3.3.17 J'utilise des manettes 8bitdo (Nes), j'étais sous une 3.3.10 avant (je crois). L'update a été long mais s'est bien déroulé, le système démarre normalement et j'ai une fenêtre "V3.3.0-beta-17" avec les 3 améliorations qui apparaissent... sauf que je ne peux pas aller plus loin. La 8bitdo est pourtant bien détectée, mais aucune touche ne permet de passer cette fenêtre. Au clavier pareil... Une idée ? Merci ! Edit : trouvé, en branchant une manette Xbox (USB) cela passe et ensuite la 8bitdo fonctionne de nouveau normalement.
                                        Beware of Darkam Onikaiju ! (from Darkam.com)
                                        • lipki
                                          lipki last edited by
                                          Alors j’espère être au bon endroit. Bug un : configuration d'une manette 8bitdo FC30 mode 1 le bouton bas fonctionne dans le menu de configuration, ce qui fait que quand on veut assigner le bouton "bas" à la commande "bas", l'appuie sur la touche "bas"nous fait descendre d'une ligne et on l'assigne à la commande "gauche". Difficile ensuite de corriger le tire. si cela ce produit, il faut revenir sur "gauche" avec une autre manette, assigner la bonne touche, remonter à la commande "haut", puis appuyer sur bas. (on reproduit le même bug mais cette fois si la touche est correctement configurer) Puis on continue sur les autres touches. (edit : malgré cette manip la touche bas ne fonctionne pas ...) J’espère avoir était clair. 😄
                                          • lipki
                                            Bug deux : Sur Street Fighter II / SNES / retroArch / PocketSNES (Puzzle de pon! / NEO-GEO / fba  également ) manette 8bitdo FC30 firmware 2.65 mode 1 La croix directionnelle (pas les boutons) de la manette 2 dirige les deux joueurs en même temps. Je vais tester sur d'autre jeux pour voir
                                            100.6k
