    V3.3.0 beta testers needed – besoin de beta testeurs
    v3.3.0 beta testers needed testeurs
    78
    401
    305006
    • esmith13
      esmith13 last edited by
      Hello. I am unable to get any segaCD games to launch in 3.3.0 beta6. I am using the same bin/cue files and same bios files I used for 3.2.0 and they worked just fine there. All other systems on 3.3.0 work fine, including megadrive which uses the same libretro core (picodrive) as segaCD. When I choose a game it fades black, then goes pitch black for one second, then fades back in to emulationstation. This is a clean install done today. The only configuration changes I have made are the RPi2 1050MHz overclock, rewind ON and changing N64 to use libretro.   EDIT: I figured it out. It was the rewind feature. SegaCD won't launch at all with rewind enabled. I want to use the feature so instead of turning it off globally I edited 'recalbox.conf' in the 'system' samba share to include the line ' segacd.rewind=0 ' to make sure rewind stays off for this system specifically. Other systems I am using successfully with rewind ON are: NES, SNES, N64 (libretro), SMS, GameGear, Megadrive, NeoGeo, GBC, GBA, PSX, PCengine. Hope this info helps someone else out. I think ' segacd.rewind=0 ' should be added to the default config file in the next update unless it can be fixed so rewind can work. At the very least the FAQ should tell you how to fix this.   Thanks in advance for any help!
      My Raspberry Pi's:
      Pi A, Pi B, (2) Pi B+, (2) Pi 3
      Currently looking for a reason to buy a Pi Zero or two ;-)
      • capitaineflam25
        capitaineflam25 last edited by
        Bonjour, vraiment top cette 3.3.3 beta, bravo pour le super travail réalisé. La nouveauté que j'apprécie particulièrement est la notion de favoris, du coup je me permet de partager quelques remarques suite à leur utilisation: il est facile de perdre un favoris en appuyant par mégarde sur Y, serait il envisageable de désactiver l'appui sur Y lorsque l'on est en affichage "favoris uniquement" ? J'imagine que ça ne pourrait pas plaire à tout le monde, peut être sous forme d'une option du .conf. Moins gênant : il n'est pas facile de constituer sa liste de favoris du fait qu'on revienne toujours en début de liste. Pour que ses favoris soient sauvegardés il faut éteindre proprement son Pi, donc il faut passer par la navigation dans les menus. Pourrais t'on imaginer une combinaison de touche, par ex. HOTKEY+SELECT+START qui ferait apparaitre directement le menu d'arrêt : "Éteindre/Redémarrer" ?
        • neko
          neko last edited by
          +1 on Eric's suggestion. The following lines should be added to the default recalbox.conf due to startup problems or performance issues.   virtualboy.rewind=0 sega32x.rewind=0 segacd.rewind=0 psx.rewind=0 fbalibretro.rewind=0 vectrex.rewind=0
          • digitaLumberjack
            @neko @Eric i'm ok with that, can i count on you to create an issue on github with this list ?
              I did a pull request with this change. Thanks for the feedback @neko @Eric
              • esmith13
                Atari 7800 and GameBoy break with rewind as well. Odd as it is GameBoy Color (same emulator as GB?) works with rewind. Atari 2600 works as well but the 2600 and 7800 use different emulators...   Eric
                My Raspberry Pi's:
                • nicocalv
                  nicocalv last edited by
                  @rockaddicted Salut voici mon fichier .conf https://onedrive.live.com/redir?resid=3EB49E84D6F1BC9!176027&authkey=!AG5kJwXGBWCJydw&ithint=file%2Cconf Je l'ai remis d'origine. Si tu as une idées, je suis preneur.   A plus.
                    Guest last edited by
                    Bonjour, est-il possible de rajouter pour la gameboy l'extension .sgb. Le peu de jeu tester avec cette extension fonctionne donc pourquoi ne pas le rajouter dans les disponibles de base. Et il semblerait que le scrapping virtual boy fonctionne, il est possible de récuperer les bonnes jaquettes quand on passe par editer les données du jeu.
                    • aaroncastello123
                      aaroncastello123 last edited by
                      What I should do to play with this xbox360's gamepad?   Is the original of Xbox360, I'm conected to wifi with the rsp2. I'm trying to configurate it to help with the beta6
                      • neko
                        neko last edited by
                        Hi aaron, you have a wireless gamepad and you will need a "Xbox 360 Wireless Gaming Receiver for Windows" for it to connect. The cable you are using is only for battery charging. It has no data connection to the USB port.
                        • neko
                          neko last edited by
                          Just got my hand on a 8bitdo Zero controller and I am happy to say that it works great on Recalbox. But unlike its big brothers, this is a Bluetooth-only device, it will never work as a USB wired gamepad, also there is no firmware update available. For bluetooth pairing, make sure you press START + R to switch it on in Windows Joystick mode.   Compatibility chart updated here: https://github.com/digitalLumberjack/recalbox-os/wiki/8bitdo-on-recalbox-(EN)   Thanks and lets keep things going everybody ;-D
                          • aaroncastello123
                            Thanks neko! Can you post a link where I could buy the xbox receiver?
                            • neko
                              neko last edited by
                              Sorry aaron I didn't brought mine online so I don't have any reliable link to post. beware that buying this thing is a little bit tricky because fake/third-party mocks up are everywhere. make sure you get an authentic/genuine one as compatibility does matters.
                              • ivwshane
                                ivwshane last edited by
                                I bought this one and it worked fine:   https://www.amazon.com/gp/aw/d/B000HZFCT2/ref=ya_aw_oh_pii?ie=UTF8&psc=1
                                • myop
                                  myop last edited by
                                  Hello je viens d installer la beta 7 et : - impossible de faire une recherche bluetooth et de connecter ma snes30 quand je lance la recherche ca indique recherche en cours un quart de seconde et "aucune manette détectée" quasiment dans la foulee Heureusement il reste mon stick mais : - gros probleme d affichage quand je sors d un emulateur pour revenir sur ES :(( J ai bien le son mais l image est brouillée suis toujours en sortie composite sur ecran cathodique (global.videomode=default) ca m avait deja fait ca sur une des premieres beta mais cela avait été corrigé sur la suivante Help merci EDIT : j'ai testé controllers.bluetooth.enabled=0 et la recherche bluetooth refonctionne. La manette ps3 se reconnecte également ce qui n'était plus cas avant. Mon probleme d'affichage est également reglé même si je ne pense pas que ce soit lié à la désactivation de controllers.bluetooth.... bizarre je n'ai changé rien d'autre
                                  • actarus1973
                                    actarus1973 last edited by
                                    Salut à tous, Sur la beta 7 : impossible de se connecter en wifi à la box Pourtant il a bien fait la MAJ de la beta 6 en wifi
                                    • kintaro-oe
                                      kintaro-oe last edited by
                                      Hello! Idem! Problème de wifi! Moi je suis sur la beta 6, et je n'ai toujours pas réussi à me connecter à la box! J'utilise le dongle wifi officiel : https://www.raspberrypi.org/products/usb-wifi-dongle/ C'est ma première connexion par contre! J'ai peut-être loupé quelque chose? Bisous!
                                      • pumpkinrv
                                        pumpkinrv last edited by
                                        Même problème constaté avec le Wi-Fi suite au passage à la version 3.3.0-beta-7 alors que les identifiants du réseau sont corrects dans le fichier recalbox.conf. Le Wi-Fi fonctionnait très bien avec les versions bêta précédentes.
                                        • colganfew
                                          colganfew last edited by
                                          Hello! In the beta 7 shaders work perfectly. In the wiki it is said to lie buttons are Hotkey + L3 or R3 but really are L2 and R2. https://github.com/digitalLumberjack/recalbox-os/wiki/recalbox.conf-%28FR%29 I'm having problems with bluetooth, use an Asus USB-BT400 Bluetooth 4.0. I have to remove it and put it on hot to connect the PS3 controls. Regards.
                                          • neogeoaddict
                                            neogeoaddict last edited by
                                            salut, au vu des bugs de la beta 7 je suis resté sur la beta 6. par contre je voulais me faire une micro sd dédié a la psx et sur le github la beta 6 n'est pas en ddl. ca passe de la 5 a la 7. est ce possible de la rajouter ? ou la 8 sera peut etre la rapidement sans les bug. merci
                                            100.6k
