    Solved Need help with hotkey
    need help hotkey
    2305
    • jonjon1977
      jonjon1977 last edited by
      In game when I use rewind or try to select save states squares show up on bottom of my screen not words
      • lackyluuk
        @jonjon1977 Which version of recalbox do you use?
        jonjon1977 1 Reply Last reply Reply Quote 0
        • jonjon1977
          jonjon1977 @lackyluuk last edited by
          @lackyluuk 4.1.0 is what it says
          Q
          • NeeeeB
            NeeeeB last edited by
            If you see yellow squares at the bottom then this means that Retroarch isn't loading a font.
            You likely don't need to delete anything, just navigate to your Retroarch Config here: /recalbox/share/system/configs/retroarch/retroarchcustom.cfg
            Then add this line to the Config: video_font_path = /storage/assets/xmb/retroactive/font.ttf
            Vieux geek ^^
            • lackyluuk
              @jonjon1977 Actually it should be solved in 4.1 stable. But just follow @NeeeeB s proposal and check 🙂
              • jonjon1977
                @neeeeb thanks, that worked for me.. Problem solved
