    Remote Control Recalbox - device required?
    remote control recalbox device required
    4940
    • farbkasten
      farbkasten last edited by
      Hello,
      I've tried to make a remote control work with this manual Infra red remote control on the Recalbox (EN), but it doesn't work.
      Everything works until i need to enter the line mode2 -d /dev/lirc0 -r -m.
      It shows the --raw option requires a --device instead of the numbers shown in the manual.
      What should i do to make it work?
        Substring @farbkasten last edited by
        @farbkasten try mode2 --device /dev/lirc0 -r -m ? Which board are you using ?
        farbkasten 1 Reply Last reply Reply Quote 0
        • farbkasten
          farbkasten @Substring last edited by
          @substring I've used a Raspberry Pi 2, today i bought a RPi 3. I will try it again soon.
          • farbkasten
            farbkasten last edited by farbkasten
            @Substring I've tried it today with my new RPi 3 but it still says: The --raw option requires a --device.
            What should I do now?
              rockaddicted last edited by rockaddicted
              Hi received TSOP4838 modules this week, but didn't have time to test.
              I'll try it and correct the wiki if needed.
              I'll post here once tests done.
              • farbkasten
                Thank you, i have a TSOP4838 too and over a year ago in Recalbox 3.3 it worked with this wiki manual.
                Now in Recalbox 4.1 it doesn't work, I hope you find a fix for this problem.
                  rockaddicted @farbkasten last edited by
                  @farbkasten Hi I fixed the wiki, can you retry please ?
                  • farbkasten
                    @rockaddicted Thank you, now it works but i have another problem.
                    When i'm finished the recording of all buttons i want to record it says i should press enter to exit but it didn't work.
                    What am I doing wrong?
                      Ok so wiki corrected, you can check diff here :
                      https://github.com/recalbox/recalbox-os/wiki/Infra-red-remote-control-on-the-Recalbox-(EN)/_compare/d9f579c9f28ebc2a12a90739eca199d47c3a14f6...d581f4185df4790adc80ca3219fd59404521d57b
                      Restart from 0 and tell me if you have a problem
                      • farbkasten
                        @rockaddicted Same problem again. As i described in my last post it doesn't finish recording when i'm pressing enter.
                        When i'm pressing enter it just getting downwards, as you can see in the photo above.
                          @farbkasten I really don't know.
                          I tried it many times to correct the wiki and take the screenshots, and I didn't have this issue.
                          Once mapping over, I pressed enter key, and the software asked me to press many time the same button, and that was over.
                          Did you affect the button to different functions ?
                          Did you try with an other one remote ?
                          I have one that get stuck on previous step.
