    ps4 dualshock 4 original issue with hotkey and 4.1
    GamePad/GPIO/USB encoder
    ps4 dualshock original issue hotkey
    2958
    • Mathieu Shamok Poirier
      Mathieu Shamok Poirier last edited by Mathieu Shamok Poirier
      my ps4 dualshock doesn't work correctly (as on 4.0) anymore.
      everything is ok, then i change shader with hotkey + R2 ... after that
      hotkey is use as a toggle button + change shader everytime we press it !
      it is a bit anoying 😕
      it does on everygame i try
      my other controller Hori Fighting Commander PS4 ...works perfectly
      • Stitchusa
        Stitchusa last edited by
        Hello,
        About ur issue, do you have massive unwanted input in Kodi ? Cause I think I have the same problem.
          i don't know , i desabled kodi ... I don't use it 😕
            @acris can you confirm the bug on your side ?
              @Substring i dont use ps controller and kodi
              • Stitchusa
                It look like the hotkey still pushed after a manipulation in games. It happen too when I make a savestate.
                  Substring @acris last edited by
                  @acris the question is using a shader on RA then the pad goes mad
