    Unable to stop Emulationstation in 4.1
    unable stop 4.1
    6725
    • Matra
      Matra last edited by
      I'm loving the changes in 4.1 but I've had to make my own gameslist for Dreamcast and PSP with the data I want... but I can't upload it as I can't get it [emulationstation] to stop!
      There is no stop button in the 'online manager' - only Start ES and Restart ES
      When SSH and sending /etc/init.d/S31emulationstation stop, the return is:
      "Command '/etc/init.d/S31emulationstation stop' failed with return code 127 and error message /etc/init.d/S31emulationstation: line 24: start-stop-daemon: command not found"
      Has something changed??
      • idarius
        idarius last edited by idarius
        Hi !
        you can try killall emulationstation maybe?
        or kill $(pidof emulationstation)
        but not sure the last command work on recalbox.
        Matra 1 Reply Last reply Reply Quote 0
        • Matra
          Matra @idarius last edited by
          @idarius said in Unable to stop Emulationstation in 4.1:
          Thanks, killall emulationstation works. Then I have to go back into the manager to restart ES.
          Bit of a pain and I'm sure there's an easier way to do it all whilst SSH-d
          • idarius
            i just tested this two commands :
            /etc/init.d/S31emulationstation start
            it worked as intended, i'm on a fresh 4.1
            are you connected with root (i think so but never hurt to ask 🙂 )
            • Matra
              @idarius
              Yes I am, I can't see any reason why the commands won't work 😕
              Everything else does bar those two... I know it would make no difference but I thought maybe it was a R/W error so I took rw permissions of the SD card and tried again to no avail...
              Real head-scratcher this one...
                Substring @Matra last edited by
                @matra How have you got your 4.1 ? as an update or a fresh .img ?
                • Matra
                  Matra @Substring last edited by
                  @substring as an update,
                  I have a fresh img to try (but trying that on the Zero for the first time later today)
                  • Matra
                    Same error message for fresh install on Pi Zero W...
                      @matra Can't test on Pi0 now, but on my Pi3 :
                      # which start-stop-daemon
                      /sbin/start-stop-daemon
                      weird ...
                      • Matra
                        @substring
                        Found the issue, it's to do with the terminal within WinSCP - which works lovely on 4.0.2 but doesn't want to stop/start.
                        Opening in Putty and it works fine...
                          @matra WinSCP to pass some commands ... shame 😄
