    4.1.0 roms in NAS doesn't work
    4.1.0 roms nas doesnt
    4646
    • Shira
      Shira last edited by
      This does not seem to work anymore since 4.1.0
      https://github.com/recalbox/recalbox-os/wiki/Load-your-roms-from-a-network-shared-folder-(EN)
      jbdemonte Substring 2 Replies Last reply Reply Quote 0
      • jbdemonte
        jbdemonte @Shira last edited by jbdemonte
        @ren-tokyo On 4.1, it seems to be more easy
        There is a section for the 4.1 on the french wiki: https://github.com/recalbox/recalbox-os/wiki/Charger-ses-rom-depuis-un-partage-réseau-Samba-(par-exemple-un-NAS)-(FR)
        To resume:
        mount -o remount,rw /boot
        vi /boot/recalbox-boot.conf
        sharedevice=NETWORK
        sharenetwork_smb1=ROMS@192.168.0.1:recalbox/roms:username=recalbox,password=recalbox
        sharenetwork_smb2=SAVES@192.168.0.1:recalbox/saves:username=recalbox,password=recalbox
          Substring @Shira last edited by
          @ren-tokyo look at https://gitlab.com/recalbox/recalbox/blob/master/board/recalbox/fsoverlay/etc/init.d/S11share#L112-L130 for more details, and don't start it on wifi 😉
          • Shira
            Thanks, can't seem to get it working though. Does it maybe not support smb v2? I removed v1 from the Windows PC a while ago where I have the roms.
              @ren-tokyo no idea, it's samba 4 (dunno which version exactly)
              • Shira
                hm let me see if I got it right, these 2 go in vi /boot/recalbox-boot.conf after the sharedevice line right?
                then ROMS and SAVES would be the share names, i.e "RecalboxRoms" and "RecalboxSaves"
                sharedevice=NETWORK
                sharenetwork_smb1=RecalboxRoms@192.168.0.7:recalbox/roms:username=myusername,password=mypass
                sharenetwork_smb2=RecalboxSaves@192.168.0.7:recalbox/saves:username=myusername,password=mypass
                  @ren-tokyo said in 4.1.0 roms in NAS doesn't work:
                  This is right. ROMS and SAVES are some keywords to tell recalbox the mountpoint of the CIFS server share
                  sharedevice=NETWORK
                  this syntax is wrong
                  Shira 1 Reply Last reply Reply Quote 0
                  • Shira
                    Shira @Substring last edited by Shira
                    @substring then where is the share name? "recalbox/roms"?
                    Guessing it's lacking SMB v2 support, I will try with 1.0/CIFS tonight
                      @ren-tokyo 192.168.0.1:recalbox/saves is the share
                      • Shira
                        @substring Ok I got it working after reinstalling SMB 1.0, so I can confirm SMB v2 is not supported
                        v1 was recently in the spotlight after the recent wannacrypt virus, with many tech sites recommending uninstalling the old version:
                        https://blogs.technet.microsoft.com/mmpc/2017/05/12/wannacrypt-ransomware-worm-targets-out-of-date-systems/
                        "we also recommend two possible workarounds to reduce the attack surface: Disable SMBv1 with the steps documented at.."
                        Thanks for your help.
