    Bluetooth keyboard unusable
    bluetooth keyboard unusable
    10188
      Substring @Dragu last edited by
      @dragu d**n i found the bug ! My bad : the code that creates udev rules for 8bitdo pads was triggered for ANY bt device !
      • Dragu
        @Substring
        Congrat ! And it was new code from march version up, or also before inside ?
        Anyway, till bugfix with manual editing of es_input.cfg, the problem can be resolved. But great. 🙂
        • Dragu
          @Substring
          There is one problem that I still have. Without the keyboard, he declare USB Dragonrise as controller 0 and 1. When I just switch on my keyboard, and the bluetooth connection was not lost, everything ok. But if I must pair the keyboard again (what will change nothing in es_input.cfg), he will declare my keyboard as controller 0, and the USB Dragonrise as controller 1 and 2.
          What makes that DOS games are not working anymore because in the Dosbox keymapper you have wrong id. Just for more info.
            @dragu We have no power on the pad ordering. In your case, you should remove the udev rule for your keyboard in /recalbox/share/system/udev/rules.d/99-8bitdo.rules which erronously forces your keyboard as a gamepad. The next update won't treat any BTdevice as a 8bitdo controller ... my bad 😕
            • Dragu
              @Substring
              It's gone, thanks. Normal, most software has to much lines 😉
              100.2k
