    Recalbox 4.1 can't connect nes30 pro in Bluetooth
    GamePad/GPIO/USB encoder
    recalbox 4.1 cant connect nes30
    3724
    • ppx32
      ppx32 last edited by
      Since the migration recalbox 4.1, I can no longer connect my joypad 8itdo nes30 pro controller to bluetooth.
      I flashed with last firmware and I did forget controller in emulationstation
      Ca' you help me ?
        OyyoDams Staff @ppx32 last edited by
        @ppx32 Hi,
        You have to unpair it first. Turn the Nes30 Pro on, then push the PAIR button for more than 3 seconds to delete the previous pairing information. Then in Emulation Station, add a new controller.
        • Chris Von Görstinger
          Chris Von Görstinger last edited by
          I have the same problem.
          This does not work:
          "Turn the Nes30 Pro on, then push the PAIR button for more than 3 seconds to delete the previous pairing information. Then in Emulation Station, add a new controller."
          I reinstalled version 4.0.1 -> works
          I make fresh install of 4.1 -> does not work
          I upgrade from 4.0.1 to 4.1 -> does not work
          seems like a bug in 4.1
          Nes30pro controller tested with FW 1.7 and 4.0
          No difference.
          br chris
            OyyoDams Staff @Chris Von Görstinger last edited by
            Hi @chris-von-görstinger this should work, this is the official procedure to proceed before pairing it again. Anyway, you can reset the Nes30 Pro by holding Start for 8 seconds. Then try pairing it again (power on, push pair button for about 1 second, and then add a new controller in ES)
              Chris Von Görstinger last edited by Chris Von Görstinger
              Hello @oyyodams.
              Long time ago since this issue game up.
              Yesterday I updated recalbox to 18.x then I tested again to connect. it did not work but:
              Since Recalbox 4.0 I always used a HAMA Bluetooth USB adapter because 4.0 did not support bluethooth chip from raspberry pi 3.
              Anyway: this time I plugged out the HAMA adapter and I could use the internal Bluetooth connection of the Raspberry Pi 3.
              IT WORKED 🙂
              So I think Bluetooth worked without USB Adapter since 4.1?
              Anyway: this issue is resolved
              thank you.
                Substring @Chris Von Görstinger last edited by
                @chris-von-görstinger read the changelog and the blog ... Pi3 internal BT supported since 4.1
