    Input lag comparison between SNES Mini and Raspberry Pi with Recalbox
    input lag comparison between snes
    8533
    • MarcDK
      MarcDK last edited by
      Hi,
      I played some Super Mario World on the SNES Mini and I think my mind is not fooling me when I say Recalbox has a huge input lag in comparison.
      I put my TV in game mode (KS 7090/KS 8000 US) with 21 ms display lag. I can also choose between the XBOX 360 Pad with wireless dongle and the an USB Buffalo SNES-style Pad (wired). Are there some settings in Recalbox to save more frames to make the game feel more responsive? Any other ideas to reduce input lag?
      https://marc.tv
      • daminoutav
        daminoutav last edited by
        I have both of them + NES Mini, and I have no (or I can't see any) difference on my PC screen (1ms) 😕
        Do you use a dongle or the internal bluetooth ? The last one could be the root of the problem.
          Substring @MarcDK last edited by
          @marcdk if there was a magical recipe to reduce the input lag, we'd have done it as default 😉
          Give a try to changing the video renderer to dispmanx. To do so, edit your retroarchcustom.cfg and add video_driver = "dispmanx". No need to reboot, just start a game
          • MarcDK
            Thank you. I'll try.
            https://marc.tv
            • idarius
              idarius last edited by
              This post is deleted!
              • MarcDK
                @substring said in Input lag comparison between SNES Mini and Raspberry Pi with Recalbox:
                Are you sure about the "? Shouldn't this be
                video_driver = dispmanx
                https://marc.tv
                • MarcDK
                  I tried
                  in /recalbox/share/system/configs/retroarch/retroarchcustom.cfg
                  with no noticable impact. Any other idea or is this the point, where the SNES Mini is plain better?
                  https://marc.tv
                    @marcdk said in Input lag comparison between SNES Mini and Raspberry Pi with Recalbox:
                    Except recompile the kernel with real time patches, no
                    • MarcDK
                      What about this thread: https://forums.launchbox-app.com/topic/33911-retroarch-input-lag-settings/
                      video_driver = "dispmanx" ("gl" if you require 3D acceleration or shaders. Will add one frame of input lag compared to dispmanx driver.)
                      video_vsync = true
                      video_threaded = false
                      video_frame_delay = 0
                      video_threaded = false is not set. My the odroid be an answer? Have you tried it yourself with a SNES Mini and a NES Mini or Real Hardware in comparison?
                      https://marc.tv
                        @marcdk which board are you using ?
                        • MarcDK
                          Raspberry Pi 3. But I think there is nothing you can configure on a pi to change the input lag of appr. 3 frames according to this thread: https://retropie.org.uk/forum/topic/2019/an-input-lag-investigation/36
                          Every emulator has a lag. Even BSNES.
                          https://marc.tv
                            @marcdk anyway you can manually set these values in the retroarch configuration files if you wish to test them.
