    Copying roms directly to SD card
    copying roms directly card
    • Narkhotik
      Narkhotik last edited by
      Re: Coping roms directly to SD card
      I found out that you can also copy all your files directly to your SD card using an ext4 read/write program.
      You can chose between those two programs :
      • DiskInternals Linux Reader
      • Ext2fsd
        paradadf Staff @Narkhotik last edited by
        @narkhotik no. At least not with DiskInternals Linux Reader. As its name states... you can only READ with it.
        Narkhotik 1 Reply Last reply Reply Quote 0
        • Narkhotik
          Narkhotik @paradadf last edited by
          @paradadf Idk how, but with a bug i were able to copy a lot of games, then it stopped working... Ô.o
