    [TUTO] Installing Recalbox on the 8-B Craft "RASPIBOY"
    Community projects
    [tuto] installing recalbox 8-b craft
    9
    24
    19244
    • screech
      screech last edited by Substring
      First what is the Raspiboy :
      It's a respectfull licence project on kickstarter (pretty hard to find a project like this one so I need to say it ^^)
      An Handled PI0 Retrogaming KIT
      text alternatif
      more detail here :
      http://www.8bcraft.com/discover-raspiboy-kit/
      https://www.youtube.com/watch?v=E12CRrtb6po
      So first created for Retropie does it work with Recalbox ?
      Answer : YES VERY WELL ^^
      And this is a quick tuto on how to install it :
      • Burn the 4.1 img to the µSD (you can download it soon ^^ )
      • Edit the Config.txt on the µSD : config.txt
      • Plug a Wifi Key on USB and start
      • Config your WIFI on Recalbox "Network" Menu
      • Go to the Recalbox share from your computer (\\RECALBOX)
      • Navigate to \\RECALBOX\share\system
      • Edit "recalbox.conf"
      • Look for the "global.videomode" setting (near the end) and set it to "default"
      • Immediately reboot your Recalbox by pressing select -> shutdown recalbox
      And voila 😄
      voljega 1 Reply Last reply Reply Quote 2
        voljega Banned @screech last edited by
        @screech Thank you for the tuto !
        If i remember correctly you were the first one to speak about here and my one and only qestion is still the same :
        "HDMI output : you can connect RaspiBoy to your big TV and video automatically switch from RaspiBoy to your TV!"
        Does this feature work on Recalbox ?
        • screech
          arg ^^ I don't have mini hdmi cable to test 😢
          I'll try to find one somewhere and try to test 😉
          (But What I think : It work when you start your PI, but not in "hotplug" mode)
            @screech That would be enough 😉 .... but I'm not sure it will work like that because of the config.txt which may require changes n start up wether hdmi cable is connected or not
            • screech
              do you think something like a "Script" is possible ?
              (But first I need to find a d**n minihdmi cable ^^)
                @screech yeah we already spoke about that in another subject witsh @substring, it seemed feasible to have like two saved copies of config.txt copied over the config.txt at startup depending on the connection of the cable or not, but it was just a discussion
                • lackyluuk
                  @screech you are doing great work 😄
                  I was watching this project too. Is it still available on kickstarter?
                  Can you give some experience? How is it? 🙂 I am thinking to get one as well 🙂
                    I should, someday, check how hdmi hotplug works, and how composite takes over if the hdmi discovery failed ... So much to do, as always ...
                    • bazola
                      bazola last edited by
                      Hi screech, is your screen blurry in émulationstation and in-game?
                      I only tried with retropie so far but it looks like the pi is not sending a 320x240 signal to the screen, so there is some downscale and it looks horrible.
                      Can you please show a capture of a game running on your raspiboy?
                      I made a capture:
                      alt text
                      Up is raspiboy, down is Gcw zer0
                      • dh04000
                        dh04000 last edited by
                        @bazola
                        Double check your config file, and see if overscan is enabled in the recalbox menu. Something I changed made my screen super sharp after my initial attempt made a blurry screen.
                        Also, try rebooting, maybe the emulator started weird. I'm not 100% sure what fixed my system after that weird blurry first boot.
                        • dh04000
                          dh04000 last edited by dh04000
                          @Substring Can we add a section to the wiki for hardware specific guides for popular hardware, like this one? The minty pi 2 is another popular one if anyone could figure out how to make it work.
                          @screech Can you write this guide when complete as a wiki page? Make sure to add Substring's suggestion of adding sdtv_progressive_scan=1 to the config.txt file.
                            Substring @dh04000 last edited by
                            @dh04000 Write a wiki page for a hickstarter that won't be available again ? Technically, yes, but that's up to the community to translate and maintain it.
                            dh04000 1 Reply Last reply Reply Quote 0
                            • dh04000
                              dh04000 @Substring last edited by
                              @substring The raspiboy is going to still be produced after the kickstarter via 8bcraft. He's taking preorders for the September/October batch now.
                              • screech
                                screech last edited by screech
                                @dh04000 have you tested with and without sdtv_progressive_scan=1 ?
                                I can see no difference personnaly.
                                Evene more, I can't find where I see it, but I think this sdtv_progressive_scan=1 is just a temporary command for test and was replaced by sdtv_mode=16
                                (Need to look for that in the very long issue talking about it ^^)
                                And yes why not a wikipage, at least not only for the Raspiboy, but for all 240P screen 😉 (I think the problem is the same on every 240p Screen 😉 )
                                EDIT :
                                Found it : https://github.com/raspberrypi/firmware/issues/683#issuecomment-283471444
                                I've pushed this change to rpi-update with a slight change.
                                sdtv_progressive_scan is no more.
                                You should add 16 onto sdtv_mode if you want progressive/240p output.
                                That fits slightly more cleanly with how the firmware handles sdtv_mode.
                                Examples:
                                sdtv_mode=16 # progressive NTSC
                                sdtv_mode=0x10 # progressive NTSC (using hex notation)
                                sdtv_mode=18 # progressive PAL
                                sdtv_mode=0x12 # progressive PAL (using hex notation)
                                • bazola
                                  So, is it ok to add sdtv_mode=16 in config.txt?
                                  • screech
                                    To use the stdv_mode=16 you need the last PI firmware. So it's ok with a 4.1 (not available for now, but soon 😉 ) or you need to update the firmware (don't know if it's possible on a 4.0x, remember RPI-Update won't work on recalbox)
                                    you can try 😉 it won't break anything, at worst it just don't work ^^
                                    • bazola
                                      I'll wait for 4.1 then ^^
                                      • dh04000
                                        dh04000 @screech last edited by dh04000
                                        @screech I'm on 4.01 still. sdtv_progressive_scan=1 in my config.txt after reboot made my screen blurry, like it was alternating the rendering the same frame slightly off center each frame. It was a weird kinda blurry. More blurry is some lines of the screen than other lines.
                                        • screech
                                          Maybe I read it wrong 😞
                                          What I understand from the Issue :
                                          sdtv_progressive_scan=1 was put in february on a "custom firmware" to test
                                          sdtv_progressive_scan=1 was removed and replaced by sdtv_mode=16 on Mars and pushed to the RPI-Update Github by popcornmix...
                                          not sure 4.01 are compiled between Feb and Mars 2017... (and with a test firmware ?)
                                          But Maybe I'm totally wrong ^^ As a French guy I can misunderstand ^^
                                          The only one who can tell are the Dev guys 😉 Maybe @Substring ?
                                            Can't find anything on the net that is reliable and official regarding the value to add in the config.txt to set progressive mode. Looks like http://filthypants.blogspot.fr/2017/03/raspberry-pi-240p-composite-output.html can be fairly trusted as it is the blog of HunterK, one of the core devs of Retroarch.
                                            So yes, adding 0x10 (=16) to the desired sdtv_mode would set progressive. I wonder how would the Brazilian PAL look ...
                                            So NTSC progressive = 16, PAL progressive = 18
