    I can not connect the wifi in recalbox help please
    connect wifi recalbox help please
    • Agc
      Agc last edited by
      Hello good, I am using a raspberry pi zero w with recalbox and I do not get it to connect to the wifi I put the data in ssid and key well and still not connected. I was also looking at the command console with recalbox but I can not look at how I can change the ip, could someone make me a little guide?
      I was looking in manuals and it is assumed that the ip that I have to configure is here but what data should it change?
        Pi zero w not compatible with recalbox.
        You need to ads manually files in recalbox 4.1
        https://forum.recalbox.com/topic/7246/test-wd-pidrive-node-zero-avec-rpi0-et-rpi0-w/2
