    Solved Xin-Mo Dual Arcade lässt sich nicht komplett konfigurieren
    Controller/GPIO/USB
    xin-mo dual arcade lässt sich
    11502
      Substring @h.hansi122 last edited by
      @h.hansi122 depending how familiar you are with linux, i'd just reommend through putty :
      /etc/init.d/S31emulationstation stop
      cp /recalbox/share_init/system/. emulationstation/es_input.cfg ~/. emulationstation
      /etc/init.d/S31emulationstation start
      I'm not sure if it's es_input.cfg or es_inputs.cfg
      • h.hansi122
        @Substring @lackyluuk
        Had few time the last week, but finally managed to try it this way. Didn't work.
        When I run the commands and restart Recalbox, the Joystick doesn't work and as soon as I hit one of the buttons, a window pops up: "configure input. 2 Gamepads detected". As soon as I try to configure, I get the same problem as befor: everything works fine, I can configure the arrow keys, abxy and start, as soon as i get to the select-button. Can't configure select or any of the following buttons.
        So I finally gave up and completely reinstalled Recalbox. Didn't help. Same issues.
        In my desperation I just hit any buttons while configuring and found out something: the select button (the one I want to be the select button in my build) works fine when I try to configure it as any other button. As well, the other buttons, that didn't work befor, can be configured as any of the arrow, abxy or the start button. But again, as soon as it gets to configure the select button in recalbox, nothing works.
        So finally I guess, the problem isn't any of the hardware-buttons, but recalbox just lets me configure up to 9 buttons and not 12 buttons, as it should be.
        Sorry for my pour english, I hope I can make you understand, what I mean.
          @h-hansi122 what the f*** is happening with your encoder ... Can you send us a support archive ?
          • h.hansi122
            @Substring
            What is a support archive?
            • lackyluuk
              @h-hansi122 https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
              • h.hansi122
                @lackyluuk
                Thanks!
                @Substring
                Here's the support archive.
                  @acris regarde son archive de support : le xinmo n'est pas "correct" : un des 2 "pads" a 2 boutons de plus que l'autre, c'est normal ?
                  @h-hansi122 I can see that your xinmo is not correctly "splitted" (the fact of having 1 USB device for 2 players) : player 2 has 2 more buttons. Dunno if it's normal, that's whay I asked acris just above
                    Je peux pas je suis en vacances dur ma tablet @Substring
                      @h-hansi122
                      You need to wire your encoder as shown in the tutorial
                      https://github.com/recalbox/recalbox-os/wiki/Xin-mo-(EN)
                      and map only player 1
                      • h.hansi122
                        @acris @lackyluuk @Substring
                        Sorry for the late answer guys.
                        After rewiring the whole thing again 2 times, it finally works.
                        As I already reconfigured it a several times before, I really don't know, what I did wrong.
                        Thank you for your patience and your help, I'd have given up without you.
                        100.8k
