    Videopac
    Emulator Arcade/PC/Console
    videopac
    3492
    • carloshickman
      carloshickman last edited by carloshickman
      I have no controls in videopac emulator. It works with keyboard to start game. Then nothing from Xbox controller or keyboard
        If you're lacking the very basic politeness and info you're supposed to supply, you can't expect any help
        carloshickman 2 Replies Last reply Reply Quote 0
        • carloshickman
          carloshickman @Substring last edited by
          Apologies, I was also having an issue in editing the post to make it more acceptable. Now I know what to do I'll edit it
          • carloshickman
            @Substring appologies, I'm not rude really I had posted it and then could not find the edit button. So can I start again?
            I have installed recalbox os on a pi3. It is using an xbox360 controller through a wireless dongle. So far all the basic emulators (snes, genesis etc) work great. My issue is with the Odyssey2 emulator - I have installed the bios file - the emulator loads and I can start a game with '1' on a USB keyboard. Then I get no controller input from keyboard or controller apart from hotkey/esc to exit emulation. The only game I have managed to get to work is terrahawks.
            I can get the emulator to work under windows by modding the config file. But I am lost in recalbox
            If anybody can help that would be much appreciated
              still missing your recalbox version ...
              carloshickman 1 Reply Last reply Reply Quote 0
              • carloshickman
                @Substring sorry it's the latest version 4.0.1. Downloaded from the official site at the weekend
                  paradadf Staff last edited by
                  FYI:
                  https://forum.recalbox.com/topic/7814/odyssey2-videopac-emulator/2
                  • DAM
                    DAM last edited by
                    In Forum have a post about that:
                    https://forum.recalbox.com/topic/2315/solved-odyssey
