    battery life in recalbox ?
    battery life recalbox
    7417
    • jackalpret
      jackalpret Translator last edited by
      Hi, is it possible ?
      To have an indicator with battery remaining in emulationstation menu ?
        Substring @jackalpret last edited by Substring
        @jackalpret Hi
        Possible, i guess so, but on our todolist, not for now. If you expect an icon somewhere telling how much battery each pad has left, that's much work.
        it would be easier to have a I2S/I2C screen showing that
        jackalpret 1 Reply Last reply Reply Quote 1
        • jackalpret
          jackalpret Translator @Substring last edited by
          @Substring thanks, icon or something else in bottom of the emulation station for example.
          I use notebook sometimes without power cable 🙂
          • godhunter74
            godhunter74 last edited by
            Maybe you can have a look here
            https://github.com/WizardPC/gbzbatterymonitor
            Relier un écran I2C et afficher des informations sur les roms
            • jackalpret
              jackalpret Translator @godhunter74 last edited by
              @godhunter74 said in battery life in recalbox ?:
              thanks, but i'm using PC , not raspberry hehe
              godhunter74 1 Reply Last reply Reply Quote 0
              • godhunter74
                godhunter74 @jackalpret last edited by
                @jackalpret ask to author if he can compile for pc !??
                • godhunter74
                  Have another look here https://forum.ubuntu-fr.org/viewtopic.php?id=447412
                  Try to locale the same give us some good News !!!
                  • jackalpret
                    that a very very good idea, script to calc battery remaining ...
                    but ... how can i run with cron for example this script and put the info into emulationstation main screen ?? is it possible ?
                      you can't display anything above ES unless ES displays it itself.
                      Adding such icons are definitely not in our todo list for now
                      jackalpret 1 Reply Last reply Reply Quote 0
                      • godhunter74
                        You can try to Merge the two topics ideas, ask help to authors, here in forum, search on internet, try to understand....
                        There isn't Built in solution but i think it is possible to do it!
                        I can't do that, i haven't enought time for my project... And i don't need it...
                        I'm sorry for mistakes you Must now know I'm not english speaker but the most important is you understand....
                        • godhunter74
                          @Substring l'idee d'écran I2C est sympa mais jackalpret est sous pc, ca complique le tout....
                          • jackalpret
                            @Substring said in battery life in recalbox ?:
                            Not necessary icons. It could be maybe only text like "88% remaining" or something like that.
                              @jackalpret whichever way, that is some work. Won't be done for the 4.1, we're focusing on stabilizing it.
                              • jackalpret
                                no problem, I'm not in a hurry.
                                If you want i can help testing or trying what you want 😉
                                count on me 🙂
