    Solved How to exit a PSP game in recalbox.
    GamePad/GPIO/USB encoder
    psp recalbox
    • Tomsen
      Tomsen last edited by Tomsen
      Hi,
      The start - select button doesn't seem to work on PSP games. (to exit the game)
      And somehow I can not go into an exit menu on arch.
      Does anyone know how to go back to the emulation station menu?
      I'm using a Odroid XU4.
        Hello
        Psp is not a core for retroach. It s a standalone emulator.
        You need to use hotkey to go menu and exit
        Do you use the last version 4.1 of recalbox unstable?
        • Tomsen
          I have installed Batocera, 5.6. I'm not sure witch recalboxx version this is but I believe it is the newest.
          The hotkey does not respond.
            paradadf Staff last edited by
            Batocera is a fork of recalbox. We don't give support for it. Contact its developer.
