    Solved ColecoVision Games Not Displaying on 4.1
    colecovision displaying 4.1
    9937
    • tdelios
      tdelios last edited by
      I'm running the latest 4.1 recalbox version on my raspberry pi 3..
      I dropped in ColecoVision roms into the 'ColecoVision' folder under ROMS, but after I rebooted Recalbox, the software does not detect the games?
      Is there a different process or hidden setting in order to install and play ColecoVision roms on Recalbox 4.1 ?
        paradadf Staff last edited by
        Just check that your rom extensions are correct. Read the _readme.txt inside the system folder for it.
        tdelios 1 Reply Last reply Reply Quote 0
        • tdelios
          tdelios @paradadf last edited by
          @paradadf Interesting.. the readme says that it is looking for .col rom file extensions when most other emulators want .rom extensions instead.
          I attempted to rename a handful of 100+ colecovision roms that I know work in other emulators from a .rom file extension to a .col.. I rebooted and they are displayed in the main screen, but when I attempt to run them, none of them work.
          what type of ColecoVision roms is Recallbox looking for that is different from the defacto standard others use?
            .col roms 😉
            • tdelios
              @paradadf I did rename them to .col
              none of them work
                paradadf Staff @tdelios last edited by
                @tdelios you must then find .col roms. There nothing else to say.
                • tdelios
                  @paradadf Do you have a few .col files kicking around that the Developers tested with that they can share to community?
                  My thoughts are that the Dev Team incorporated the colecovision emulator into Recallbox but never tested it against any rom files.
                    Substring @tdelios last edited by
                    @tdelios said in ColecoVision Games Not Displaying on 4.1:
                    Doh ... You're so mean 😞 Your guess is just totally wrong. Despite we can't test every possible situation, we do test evolutions such as adding a core ...
                      did you at least added the bios file as explained in the read_me.txt file ? https://github.com/recalbox/recalbox-buildroot/blob/rb-4.1.X/board/recalbox/fsoverlay/recalbox/share_init/roms/colecovision/_readme.txt#L11
                      • tdelios
                        tdelios @rockaddicted last edited by
                        @rockaddicted I have not done that, but that brings up another great point. The entire 'bios' steps of adding the 'databases' and 'machines' folder should have been part of the installation process and not a manual process after the fact. This would be a great feature enhancement request to be added to the 4.1 release.
                        Substring rockaddicted 2 Replies Last reply Reply Quote 0
                        • tdelios
                          tdelios @Substring last edited by
                          @Substring sorry substring, didn't sound to be mean.. I've just worked with RetroPie in the past and ran into so many of features being implemented but not tested.. which is the reason why I switched over to Recalbox..
                            Now you've risen an eyebrow here ... what do you mean ?
                            • tdelios
                              @Substring As per your post providing the link which the readme.txt file indicates that I need to download the zip file, extract the contents of the 2 folders (machine & database) and then add those 2 folders to the bios folder of my recalbox.
                              Why does it require a manual effort. Should it not be part of the installation that to have the machine and database folders as part of the bios already in place? If not, at least do like RetroPie does and provide an add-on screen that allows the user to flick a switch and have it automatically do this for me.. or if I flick it off, that it uninstalls it as well.
                              Hope that clears things up.
                                @tdelios unzipping 2 folders for a single system is not worth coding a switch I'd say ... Everything is documented where it should be 😛
                                Still, you were used to retropie and want to enjoy again your past habbits. Think different, think apple recalbox 🙂 It's not such a big deal, uh ?
                                • tdelios
                                  @Substring LOL.. I hear ya.. thanks for the feedback!
                                    rockaddicted @tdelios last edited by
                                    We can't bios are copyrighted files.
