    How to emulate X68K in Recalbox
    Emulator Arcade/PC/Console
    emulate x68k recalbox
    11
    70
    42376
      voljega Banned @acris last edited by
      @acris c'est quoi le cpu cyclone ?
        @voljega
        r-type dit : A noter cependant qu'il existe une version spécifique pour ARM utilisant le cpu asm ARM cyclone (celui de picodrive.
        https://github.com/chiorex/px68k/tree/speedup qui doit être plus rapide pour les cpu ARM.
        J'ai testé mais je vois pas trop de différence peut etre qu'un oeil expert serait requis.
        Je suis aussi passé en full frame et le fps est entre 55.7 et 57
        • azvarel
          azvarel last edited by
          setting the space for by in the recalbox. ha-ha
          alt text
          Zodian Theme | #SNESProject
            Libretro Core update :
            • core option
              • Use analog
              • Joypad type : 2 buttons - CPSF-MD (8 buttons) - CPSF-SFC (8 buttons)
              What's the news , core updated :
              quick menu > Options
              • CPU speed
              • Ram Size
              • Use Analog
              • P1 Joypad
              • P2 Joypad
              azvarel 1 Reply Last reply Reply Quote 0
              • azvarel
                azvarel @acris last edited by
                @acris nice, good news!
                • Ettapowers
                  Ettapowers last edited by
                  Yeah!! I Agree with Acris, you need to follow the steps.
                  Add Cyclone CPU for arm
                  Add Menu F12 to L2 joypad
                  Few Fix keyboard
                    What's the new core updated :
                    CPU speed
                    Ram Size
                    Use Analog
                    P1 Joypad Type
                    P2 Joypad Type
                    ADPCM Volume
                    OPM Volume
                      Hello
                      https://www.libretro.com/index.php/new-core-px68k-androidioswindowslinuxmac/
                      • azvarel
                        amazing this new core, really great news, I hope to see it as soon as possible in the recalbox, of course this core has a difficulty that is not having the virtual keyboard, but you can play with it a lot.
                          @azvarel
                          What is the virtual keyboard used for?
                            @azvarel
                            I see your question on IRC.
                            you need to create playlist file with name :
                            Akumajou Dracula (1993)(Konami).m3u
                            with inside 2 lines :
                            Akumajou Dracula (1993)(Konami)(Disk 1 of 2).dim
                            Akumajou Dracula (1993)(Konami)(Disk 2 of 2).dim
                            and you must hide theses 2 files :
                            select each file game , select button > edit metadata game > hidden > ON
                            And If you need to optimize this game may you need to go retroarch menu (hotkey+B) :
                            Quick Menu > Options >
                            CPU Speed : 16 Mhz
                            Game-Options File  to create file
                            reset game.
                            And with px68 Menu (L2) need to chose frame skip : 1/6
                            thanks @voljega 🙂
                            voljega chris256 2 Replies Last reply Reply Quote 2
                              voljega Banned @acris last edited by voljega
                              @acris huh ? i'm always happy to be thanked but why in that case ? 😄
                              btw scanlines aren't used by the X68k emulator at least in 'Retro' config is it normal ?
                                acris @voljega last edited by
                                your upvote for my message 😄
                                @voljega said in How to emulate X68K in Recalbox:
                                I dont know , @rochaddicted any idea ?
                                  rockaddicted @acris last edited by
                                  @acris don't know maybe a typo.
                                    https://gitlab.com/recalbox/recalbox/blob/master/board/recalbox/fsoverlay/recalbox/share_init/system/configs/shadersets/retro.cfg#L51
                                    should be ok
                                      Hello
                                      What is the sequence to launch Genocide 2 ?
                                      Solution
                                      Genocide 2 (1991)(Zoom)(Disk 1 of 4)(System).dim
                                      Genocide 2 (1991)(Zoom)(Disk 2 of 4)(Data 1).dim
                                      Genocide 2 (1991)(Zoom)(Disk 3 of 4)(Data 2 ).dim
                                      Genocide 2 (1991)(Zoom)(Disk 4 of 4)(Data 3).dim
                                      renamed
                                      Genocide 2 (1991)(Zoom)(Disk 2 of 4)(Data A).dim
                                      Genocide 2 (1991)(Zoom)(Disk 3 of 4)(Data B).dim
                                      Genocide 2 (1991)(Zoom)(Disk 4 of 4)(Data C).dim
                                      FDD0 -> SYSTEM
                                      FDD1 -> Data A-> game start
                                      And remplace Data A To Data B
                                        @azvarel
                                        I think file hdf doesn't work on raspberry but I Think in recalbox x86_x64 may be
                                        because hdf file contains autoexec.bat or command.x for windows computer.
                                        @rtype
                                        pourquoi le format hdf ne fonctionne pas sur raspberry ? est ce un bug ?
                                        azvarel 1 Reply Last reply Reply Quote 1
                                        • azvarel
                                          @acris I believe it is more emulator bug, I have xbox classic emulator that works perfectly hdf files.
                                            @azvarel
                                            i read theses lines :
                                            @rtype writed : be sure your hdf is in SASI format, SCSI one are not supported with this core. Also be sure (hit F12) that you don"t have some fdd set , if yes unset same and reset using the gui.
                                            you can use diskexplorer to open it and see if they are Human68k HDD or SCSI. http://www.gamesx.com/wiki/doku.php?id=x68000:x680004
                                            source : https://forums.libretro.com/t/px68k-libretro/10113/165
                                            101.0k
