    N64 Pi3B 4.0.2 black screen
    Emulator Arcade/PC/Console
    pi3b 4.0.2
    6
    22
    12320
    • Maarten003
      Maarten003 last edited by acris
      Hello I can't seem to find to get the N64 games to play on my RPi3 Recalbox 4.0.2. I'm a first time user of recalbox and followed de steps in de DYI. I'm using the PS3 controller from Sony.
      The Nintendo 64 section and games load in to the recalbox but if I chose one to play de screen get black and a moment later my tv states that it can’t play the video format.
      After a few visits to the wiki and forum I've tried a bunch of stuff but didn't work and now I'm clueless.
      Now I've done a clean install, put 3 N64 games on the recalbox and put in the PS3 controller and Tv screen in the config below:
      # System Variable
      system.manager.enabled=1
      ## Recalbox API (REST)
      system.api.enabled=0
      ## EmulationStation menu style
      ## default -> default all options menu
      ## none -> no menu except the game search menu
      ## bartop -> less menu, only needed for bartops
      system.es.menu=default
      ## Emulator special keys
      kodi.enabled=1
      ## Start kodi at launch (0,1)
      kodi.atstartup=0
      kodi.xbutton=1
      ;kodi.network.waittime=10
      ## Set system hostname
      system.hostname=RECALBOX
      ## Activate wifi (0,1)
      wifi.enabled=0
      ## Wifi SSID (string)
      wifi.ssid=telenet-3AE1D
      ## Wifi KEY (string)
      wifi.key=PhUx61F3302
      ## Samba share
      system.samba.enabled=1
      ### Virtual Gamepads
      ### SSH
      system.ssh.enabled=1
      audio.device=auto
      ## Set system volume (0..100)
      audio.volume=90
      audio.bgmusic=1
      controllers.ps3.enabled=1
      ## Choose an driver between official, shanwan and gasia if you have dualshock clones (official,shanwan,gasia)
      controllers.xboxdrv.enabled=0
      ## GPIO Controllers
      controllers.gpio.enabled=0
      controllers.gpio.args=map=1,2
      ## DB9 Controllers
      controllers.db9.enabled=0
      ## db9 arguments
      controllers.db9.args=map=1
      ## Gamecon controllers
      controllers.gamecon.enabled=0
      ## gamecon_args
      controllers.xarcade.enabled=1
      system.language=en_US
      ;system.kblayout=fr
      ## Set you local time
      ;system.timezone=Europe/Paris
      updates.enabled=1
      # Update type : default to stable
      # set to unstable at your own risk to get the development version.
      updates.type=stable
      ## (string)
      global.videomode=CEA 16 HDMI
      ## Shader set
      ## (none, retro, scanlines)
      global.shaderset=none
      global.integerscale=0
      global.shaders=
      global.ratio=auto
      global.smooth=1
      global.rewind=1
      global.autosave=0
      global.retroachievements=0
      global.inputdriver=auto
      ## Here is the snes example
      ;snes.videomode=CEA 4 HDMI
      snes.core=snes9x_next
      ;snes.ratio=16/9
      ;snes.smooth=0
      ;snes.rewind=1
      ;snes.autosave=0
      ;snes.emulator=libretro
      ;snes.integerscale=0
      ## Default cores for RPi3
      gba.core=mgba
      mame.core=mame078
      nes.core=fceunext
      ## NeoGeo emulator
      neogeo.emulator=libretro
      ## If you set libretro as neogeo.emulator, the line below sets the retroarch core (fba,imame4all)
      neogeo.core=fba
      n64.videomode=DMT 4 HDMI
      # n64.videomode=default
      th0_1492463327049_WP_20170417_12_19_52_Pro.jpg 0_1492463601518_N64 games.png
      Hopefully someone can give some directions or information how to handle this. Thank you very much for any given information!
      Pepe Substring 2 Replies Last reply Reply Quote 0
      • Pepe
        Pepe @Maarten003 last edited by
        @Maarten003 in recalbox.conf try n64.videomode=CEA 1 HDMI instead of n64.videomode=DMT 4 HDMI
          Substring @Maarten003 last edited by
          @Maarten003 I guess your TV is lying regarding its supported video formats 😉 So try what @pepe sugested, then try any other mode.
          • Maarten003
            @Pepe @Substring Okay, the CEA 1 didn't work but indeed an other: the CEA 4 works. I thought to have read that i needed to take the small ones. Apparently not, thank you verry much! My collegues at work will be happy to, I was really b*mmed out, that I couldn't relive my childhood :').
            Now I can see the games are running slow but thought to have read someting about that on the wikki and will search for it.
            Thought about getting a new tv for a second there, because my mate just did plug and play ! 😄
            Again thank you very much!
              @Maarten003 we set DMT 4 to reduce CPU calculation and make N64 more fluid ... increasing the resolution makes it slower ... nothing more nothing less
              • Rubem Moura
                Rubem Moura last edited by
                Hi, guys.
                I have the same problem and the changes n64.videomode=DMT 4 HDMI to n64.videomode=CEA 1 HDMI doesn't worked for me.
                I have tried to do the n64 work in my rasp2 since three weeks ago, and I don't have success. I searched in the forum and tried all supposed solutions, but still don't work.
                I saw in the forum who the problem may be due to the byte format of the roms, the screen resolution, and the configuration of the joysticks.
                So, I kept trying.
                • My roms of n64 is Byteswapped;
                • I tried changes the n64.videomode to all option who have resolution 640x480 from my TV (i tried also in a monitor);
                • I tried with two differents controllers (ps2 format);
                • Controllers model:
                But still, the n64 returns to emulation station after the black screen.
                Please, help me, guys.
                I can try with a clean installation.
                • abunille
                  abunille @Rubem Moura last edited by abunille
                  @rubem-moura
                  Have you setup the Joysticks on UI correctly (The "L" Buttons also)?
                  Rubem Moura 1 Reply Last reply Reply Quote 0
                  • Rubem Moura
                    Rubem Moura @abunille last edited by
                    Hi @abunille
                    Thanks for your reply.
                    I used the menu to configure the joysticks (Controller Settings-> Configure a Controller).
                    In this menu, he asks me to choose the L1 R1 L2 R2 buttons, and i set according to ps2 controller model (the controller of the pictures above).
                    I don't know if this procedure is correct to n64.
                    • abunille
                      @rubem-moura
                      Ok, the joystick configuration seems ok.
                      As i can read below, you have already change the videomodes.
                      https://github.com/recalbox/recalbox-os/wiki/N64-%3A-return-to-ES-%28EN%29
                      With other systems the games are starting and the joysticks works in recalbox?
                      Have you checked a game without plug in a joystick (only with keyboard)?
                      The only problems i know are
                      • wrong videomode
                      • joystick not configured ("L") or is not supported
                      • bad roms
                      • Rubem Moura
                        Hi @abunille ,
                        Yes, i tried to do like explained in this tutorial (https://github.com/recalbox/recalbox-os/wiki/N64-%3A-return-to-ES-(EN)), but still don't works.
                        • With all others systems (NeoGeo, MegaDrive, SNES, PS1...), i can play with this two joysticks, without any problem.
                        • Yes, i tried do this after see in other topic, but still don't works
                        I will put here my configuration file and recalbox.log.
                        • abunille
                          @rubem-moura
                          strange.
                          The rom extensions are .n64 .N64 .z64 .Z64 .v64 .V64, right? Not .zip
                          For your configuration and log, please have a look here:
                          https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-%28EN%29
                          Rubem Moura 2 Replies Last reply Reply Quote 0
                          • Rubem Moura
                            @abunille
                            Yes, my roms aren't .zip.
                            And i checked with toll64 application, who my roms are byteswapped.
                              Did you check if your screen is compatible with the default N64 video mod ?
                              • Rubem Moura
                                Rubem Moura @rockaddicted last edited by
                                Hi @rockaddicted ,
                                When i run the comand tvservice -m DMT and CEA, the output contains the resolution 640x480 like an option. I tried use them but still don't works.
                                Here my log file with same information when i try run n64:
                                  ok so, upload support archive, I'll check your setup (look @abunille post).
                                  Then log on ssh, /etc/init.d/S31emulationstation stop then /etc/init.d/S31emulationstation start. Now keep this ssh window open, start a N64 game and check in this ssh window if an error is displayed.
                                  • Rubem Moura
                                    @abunille ,
                                    i can't get the recalbox-support.sh file now (i'm working), but i will put this file here later.
                                    • Rubem Moura
                                      Ok @rockaddicted ,
                                      I will do this later (i'm working) and will put the result here.
                                      Thanks!
                                      • Rubem Moura
                                        Hi guys!
                                        Ok @abunille and @rockaddicted , i do a clear installation to undo the old any changes.
                                        After this, i configured again the joystick (Clone), and put an video here to you check if is correct. Youtube Video
                                        I put the n64 roms into the corresponding folder. All roms in format .n64 and byteswapped (checked with tool64 application).
                                        So, i tried start n64, without any modifications in recalbox.conf file and still don't works.
                                        Ok, i open the recalbox.conf file, and i compare with other recalbox.conf file from the GitHub. In my file, was missing an text, who defines some configuration to n64:
                                        So, i copy and paste this stretch to my file, and tried start n64, but still don't works.
                                        I tried apply the modification about the video mode (link), changing n64.videomode=DMT 4 HDMI to n64.videomode=CEA 1 HDMI , but still don't works.
                                        This is my output from tvservice command: 0_1501197056735_tvserivce.PNG
                                        After this, i do the processes to get the recalbox support file, described in this link. And here is my support file: GoogleDrive File
                                        So, i get the log via ssh with the commands /etc/init.d/S31emulationstation stop and /etc/init.d/S31emulationstation start, and here is the output after i tried start a n64 game: 0_1501196926433_log error.PNG
                                        Ok guys!! Please help me!
                                        • Rubem Moura
                                          Just remembering: Now, the recalbox version is 4.0.1, and my rasp is pi2.
                                          abunille 1 Reply Last reply Reply Quote 1
                                          • abunille
                                            @rubem-moura
                                            we must wait for @rockaddicted to read the support file, he is more a pro than me 😉
                                            But what i see in your log is (i hope i am right):
                                            • Machine model: Raspberry Pi Model B Plus Rev 1.2 (seems to be a pi1)
                                            • Load BCM2835 DMA engine driver (also a sign for pi1, pi2 has BCM2836)
                                            • hw perfevents: enabled with armv6_1176 PMU driver (also, pi2 has Cortex-A7)
                                            And this means it is a pi1 and not pi2.
                                            And how i know a pi1 is not supported with n64.
                                            But how i write above, better to wait for @rockaddicted
