    4.0.1 Recalbox Controllers won't work
    GamePad/GPIO/USB encoder
    recalbox4.0 shanwan controllers controller ps3 raspberry pi 3
    3897
    • Babelini
      Babelini last edited by
      Hello Community
      I just bought 2 USB Wireless Controller, that means 1 USB Dongle 2.4GHz which connect 2 Wireless Controllers. The Controllers are from Shanwan (China) they are Ps3 Dualshok Clones.
      Now i tried to connect them to my Recalbox on my Pi3 to play Mario Kart 64 whith 2 players.
      When i connect one of them i can use one controller but the other one won't work.
      When i connect the other controller (with configurate controller) it works, but the other controller won't work.
      So i can use only one Controller at the same time 😞
      I tried to solve it in the config file but it doesn't work.
      What can i do? I hope you can help me.
      Thanks in advance
        Substring @Babelini last edited by
        @Babelini Hi
        Most of times, 2 controllers on the very same USB means using USB quirks. Can you make a support archive please ?
        Babelini 1 Reply Last reply Reply Quote 1
        • Babelini
          Babelini @Substring last edited by
          @Substring
          One usb that means i have one receiver usb dongle in the raspberry for the 2 controllers. But the recalbox contect the 2 controller as one so i can only use one at the same time.
            @Babelini linux just sees 1 usb device, so it's not supposed to be i n fact 2. The most known example is the xinmo : 1 usb, 2 players. The trick is to use a tweak called usbquirks that forces linux to "seperate devices". Tht's why i need a support archive (see tge wiki how to do it)
            Babelini 2 Replies Last reply Reply Quote 0
            • Babelini
              @Substring i'm very sorry but i don't know what i have to do. what is a support archive? can you give me a link?. Tanks a lot in advance and sorry that i'm so Inconvenient.
                paradadf Staff last edited by
                https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
                Babelini 1 Reply Last reply Reply Quote 0
                • Babelini
                  Babelini @paradadf last edited by
                  @paradadf thanks a lot for helping, i try it tomorrow
                  • Babelini
                    @Substring Hi i have here on this link my support archive, i hope you can help me. Thank a lot.
                    Support archive link:
                    http://www108.zippyshare.com/v/OoQN3Eqs/file.html
