    N64 Saves states
    Emulator Arcade/PC/Console
    saves
    3719
    • Pepeu
      Pepeu last edited by
      Hi,
      I am using 4.0.2 version on Pi 3 model B and can't make save states on N64 emulator with any of the cores. Is there any tip or solution?
      Thanks in advance
        Hello
        saves states don't exist.
        it's not a libretro core.
        you need use save in game.
        Pepeu 1 Reply Last reply Reply Quote 0
        • Pepeu
          Pepeu @acris last edited by
          @acris Bad news....but thank you for the answer
            paradadf Staff last edited by
            Actually, there are save states on n64.
            There is only one core on 4.0.X, rice, n64 and gliden64 are plugins.
            • Pepeu
              Then can I save state my game? The hotkey combinations does not work
              • levendis32
                levendis32 Translator Banned last edited by
                This post is deleted!
