    Solved Cannot connect Ipega 9021
    GamePad/GPIO/USB encoder
    cannot connect ipega 9021
    7635
    • Robsdedude
      Robsdedude last edited by
      Hi,
      I'm trying to make my Ipega 9021 bluetooth controller work. But I simply won't. I've seen that support for it has been added with 4.0.0-b4 (I'm running 4.0.2). My Bluetooth dongle is the CSL - V4.0 USB nano. I can pair the controller with my recalbox. But it won't pair automatically wenn turning the controller off and on again and I can't configure the controller as it's not recognized...
      Any Ideas?
      PS: I've seen two other posts in this forum on this, but the didn't help me...
        Hello @Robsdedude
        connect only your gamepad mode gamepad not keyboard mode and disconnect keyboard and mouse.
        and post your archive recalbox-support.sh : https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN)
        • Robsdedude
          Robsdedude last edited by Robsdedude
          Thanks for the hint. The gamepad is already in gamepad mode. But how do I enter the config menu when I disconnect the keyboard? I can disconnect it on the screen that tells me to long press any button on my gamepad. But still the gamepad isn't recognized. Interestingly the home button and the media control buttons on the gamepad (if long pressed) trigger the keyboard config to pop up...
          My support archive https://oc.xia.de/index.php/s/9FkMoBAO3mLiyC1
          • Robsdedude
            This post is deleted!
            • Robsdedude
              Update: I can make it work using the controller in keyboard mode. But
              • I don't want to change the keyboard bindings (just in case I mess up things I'd like to be able to fallback to a keyboard).
              • The hotkey does not work inside the SNES-Emulator.
              Strange: The controller does only reconnect if starting it in pairing mode (i.e. HOME+A) but not on normal power up (i.e. only HOME).
              • Robsdedude
                Finally!
                By manually updating /etc/udev/rules.d/99-joysticks-exotics.rules to https://raw.githubusercontent.com/recalbox/recalbox-buildroot/master/board/recalbox/fsoverlay/etc/udev/rules.d/99-joysticks-exotics.rules I could make it work!
                EDIT 1: The only thing that still does not work is the hotkey. I bindend select to be the hotkey (because HOME+SOME BUTTONS have a controller internal binding). Any ideas what could be the problem here?
                EDIT 2: I just noticed that the start button of the controller also does not work.
                • Robsdedude
                  Ok. I made it work now completely (including start and select buttons) by setting global.inputdriver=sdl2 in the config. Thus, this thread can be closed.
