    GameSir G3w Wired Game Controller cant be found
    GamePad/GPIO/USB encoder
    gamesir g3w wired cant
    5617
    • Lorenzo Cioncolini
      Lorenzo Cioncolini last edited by
      GameSir G3w Wired Game Controller is a controller compatible with android windows and ps3 console so i think its strange that my raspberry pi 3 cant even see it, i try with a generic usb controller and everything work but i need gamesir controller for his stand for making it portable. Sorry for bad eng
      paradadf falodegomaespuma 2 Replies Last reply Reply Quote 0
        paradadf Staff @Lorenzo Cioncolini last edited by
        @Lorenzo-Cioncolini what RPi version are you using? What recalbox version? The internal bluetooth in the RPi3 is only activated since the 4.1 unstable.
          Im using RPi 3 B and with recalbox 4.1, the controller is not bluetooth its use usb port
          https://www.amazon.it/GameSir-G3w-Controller-Gamepad-Joystick/dp/B019PSLC36/ref=sr_1_2?ie=UTF8&qid=1489518282&sr=8-2&keywords=gamesir
            @Lorenzo-Cioncolini ups, sorry... totally missed the "wired" part.
            I suppose the controller has different start modes. Have you tried with all of them? Which one does it have?
            On recalbox.conf you should try changing the inputdriver from auto to sdl2.
              How can i easily change recalbox.conf?
                Substring @Lorenzo Cioncolini last edited by
                @Lorenzo-Cioncolini http://recalbox/ 😉 Unless you're on mac/linux http://recalbox.local/
                  ok i try change recalbox.conf but nothing change
                    @Lorenzo-Cioncolini try evtest from putty to see if linux sees events
                    • dudu
                      dudu last edited by
                      @Lorenzo-Cioncolini have you solved your issue ?
                      I also bought this controller and I'm meet the same problem. I tried to enable XBox controller instead of ps3 one, without success.
                      Any linux driver seems available for the G3W.
                      • falodegomaespuma
                        falodegomaespuma @Lorenzo Cioncolini last edited by
                        @lorenzo-cioncolini Hi, I have the same problem, did you solve the problem? Please contact me if you did it because I am quite desperate
