    [Release] Klassiko
    Themes & Interface
    [release] klassiko
    7
    9
    6858
    • RetroWilly
      RetroWilly last edited by RetroWilly
      Well, had some delayment since not everything was working as it should and had a crash on a system on the last moment, but it's fixed. So here it is.
      "Klassiko" for Recalbox
      • 4.1 Ready
      • System backgrounds
      • Artwork XML resized
      • Some logo change up
      • All systems covered
      alt text
      alt text
      alt text
      alt text
      alt text
      alt text
      Downloadlink: https://goo.gl/hNpYwS
      Enjoy, and again apologies for the delays 🙂
      Hello :)
      • screech
        screech last edited by
        Nice theme.
        Picture aren't too much "heavy" with lot's of plateform activated ?
        And I think you must try UXS to scrape your picture 😉 (solo screenshot or cover are so sad ^^)
        • RetroWilly
          @screech, Thanks.
          I've made sure it is light by cropping pictures. I agree about the XML haha, however this is just for some testing and to post screens 🙂
          Tomorrow my nano usb flash drive will arrive, and then i will put my roms on that as romstorage. Will put a clean install also on it, and with that the right artwork.
          Hello :)
          • maximus37
            maximus37 last edited by
            @RetroWilly Very nice work and thank you for this great theme!! 🙂
            • Benny
              Benny last edited by Benny
              @RetroWilly Thanks for this super awesome theme... Love the musics ! Only thing I noticed is that the "last played" and "times played" lines are inverted in French language.
              RetroWilly 1 Reply Last reply Reply Quote 1
              • RetroWilly
                RetroWilly @Benny last edited by
                @Benny, Thanks. I will look into that 🙂
                Hello :)
                • jackalpret
                  jackalpret Translator last edited by
                  congratulations, it looks nice 😉
                  • gigante154
                    gigante154 last edited by
                    @retrowilly Hi, the download link is broken, you have another ?
                    • Fab2Ris
                      Fab2Ris Staff last edited by
                      Could be great to think about EDIT EACH FIRST THEME POST to indicate before anything... witch version of Recalbox is compatible with this theme.
                      Like : TESTED/Works on Recalbox 6.0 RC2 (DATE OF TEST)
                      And edit the post title, for exemple : THEME : Next Pixel (OK Recalbox 6.0, April 15), or THEME : Next Pixel (Recalbox 18.xx.xx OK, Recalbox 6.0 WIP)
                      This information must be on the name of the theme + topic, to see if there is update avaiable for theme's users.
                      And on the other hand, it's very important, to see if there is all systems supported, and not particular problem...
                      What do you think about ?
                      Tuto Maker et Community Manager de Recalbox (Facebook/Twitter/Instagram/YouTube...)
