    Recalbox on a 5 inch HDMI display = how to set the resolution?
    recalbox inch hdmi display
    • dormonid
      dormonid last edited by dormonid
      I got a 5 inch hdmi monitor with resolution of 800x480 for a project and tried to run recalbox on it.
      At first, the screen was all messed up, since the Pi coudnt find the proper resolution. So I found online how to change the screen resolution via config.txt.
      So I held shift and via noobs edited the config.txt with this parameters:
      hdmi_force_hotplug=1 (not sure why they asked to do this command, but I did it anyway)
      hdmi_group=2
      hdmi_mode=87
      hdmi_cvt= 800 480 60 6 0 0 0
      And the result was this:
      https://drive.google.com/file/d/0B875tKE2-GugczFxOXhOa2dnYW8/view?usp=sharing
      The problem happens when I tried to start any game from any emulator from any console.
      It doesnt keep the same resolution. It looks like this:
      https://drive.google.com/file/d/0B875tKE2-GugZEVWcG9LUnRDR2s/view?usp=sharing
      So... where else do I need to go to config the resolution? Where else I have to check ? And how?
      Thanks for helping!
      • ian57
        @dormonid : in recalbox.conf change videomode to default instead
        global.videomode=default
        see https://github.com/recalbox/recalbox-os/wiki/TFT5-Screen-HDMI-(EN) for details... everything is explained
