    Unsolved cant connect to www in recalbox pi zero w -> recalbox 4.0.3 soon
    cant connect www recalbox zero
    6
    10
    6203
    • SHLONKY
      SHLONKY last edited by acris
      hi, ive just got the new pi zero w and installed recalbox but im having issues connecting to the web.
      i used noobs to install and the pi connected to the web to download files so i know the wifi is working, but once i select an OS it boots up and theres no connection?
      ive entered my settings into the options in recalbox/emulationstation but it says "configuration error" even though its correct and theres no options to search for wifi?
      Its drivin me mad and cant understand how somethin so simple as connecting to wifi could be so difficult 😞
      any ideas?
        Hello
        recalbox is not compatible with rpi0 W for the moment.
        The team works to add rpi0w in recalbox 4.0.3.
        This build will be available soon
        supramick 1 Reply Last reply Reply Quote 1
        • supramick
          supramick @acris last edited by
          @acris Excellente nouvelle 🙂 j'ai fais quelques essais sur mon Pi Zero W et forcement le wifi est pas pris en charge, pire j'arrive pas a faire un installe propre à partir d'une SD fraîchement formaté et le fichier ZIP.
          Désolé de répondre en FR dans la section EN mais je voulais pas recréer un sujet alors que je peux avoir la réponse dans une autre section 😉
          rockaddicted 1 Reply Last reply Reply Quote 1
            rockaddicted @supramick last edited by
            @supramick rien ne t'empêche de faire l'effort d'écrire en english, même si tu es frenchy 😉
              Lequipe travaille pour son integration
              Les tests senchainent depuis vendredi. Quand tt sera integré une version recalbix 4.0.3 devrait sortir
                Substring @SHLONKY last edited by
                @SHLONKY that's because noobs and recalbox are 2 distnct OS. We can't add wifi and bt to 4.0 due to the old kernel running on it
                • summunx
                  summunx Banned last edited by
                  Wishing inpacientemente the version for pi zero W, go chagrin when I came today and see that did not work ...
                  Many thanks for your work
                  • summunx
                    Could you specify more that 'soon'? I know it's impossible to know even for you, but about?
                    least 2 weeks, less than 1 month? less than 3 months?
                    Thank you
                      rockaddicted @summunx last edited by
                      @summunx said in cant connect to www in recalbox pi zero w -> recalbox 4.0.3 soon:
                      Thank you
                      Sorry to have a life, a job, beside this project.
                      So when we say soon.... it is soon.... no timelime to communicate.
                      But if you are impatient, and the job is not going fast enough for you. You have access to the source code, so you can fix this issue, build a fixed recalbox version and push your work on the repository.
                      If don't, stop to press us.
                      Thanks.
                      summunx 1 Reply Last reply Reply Quote 0
                      • summunx
                        summunx Banned @rockaddicted last edited by
                        @rockaddicted said in cant connect to www in recalbox pi zero w -> recalbox 4.0.3 soon:
                        Thank you
                        So when we say soon.... it is soon.... no time lime to communicate.
                        Thanks.
                        my intention was not to press, I'm sorry if you've seen it so.
