    cant add favorites with controller
    cant favorites
    11270
    • jackalpret
      jackalpret Translator last edited by
      version 4.1 pc unstable ... I touch favorite button and doesnt add the game to favorite ... but if I press select, then edit game options , and turn ON on favorite option it works. ...
      I remember it works before ... maybe I change anything and now doesnt work ?
      • azvarel
        azvarel last edited by
        @jackalpret The problem of not adding to favorites, may be related to theme
        Check for rows containing md_favorites and md_lbl_favorite if they exists.
        Zodian Theme | #SNESProject
        jackalpret 1 Reply Last reply Reply Quote 0
        • jackalpret
          jackalpret Translator @azvarel last edited by
          @azvarel I dont understand ... I can add in "select" menu via editing game options , but dont with controller (or keyboard) button.
            paradadf Staff @jackalpret last edited by
            @jackalpret as @azvarel said, it needs to be supported by the theme. Just try using the official one and see the difference.
            • jackalpret
              jackalpret Translator @paradadf last edited by
              @paradadf said in cant add favorites with controller:
              yeah , both of you have the reason 🙂
              can i add this "option" to my theme ?
                @jackalpret azvarel just told you the two fields thst need to be added to the xml files of the theme. In your case I would just compare yours wirh the official and see what other fields are missing.
                • jackalpret
                  @paradadf In the new theme I dont have anything with "favorite" ...
                  lines with md_ in my theme:
                  <text name="md_lbl_publisher, md_lbl_lastplayed, md_lbl_playcount, md_publisher, md_playcount, md_description,md_lbl_rating">
                  		<fontPath>./main/fonts/Dosis-SemiBold.ttf</fontPath>
                  		<fontSize>0.01</fontSize>
                  		<pos>-50 -50</pos>
                  	</text>
                  	<datetime name="md_lastplayed">
                  		<pos>-50 -50</pos>
                  	</datetime>
                  	<text name="md_lbl_releasedate, md_lbl_developer, md_lbl_genre, md_lbl_players">
                  		<forceUppercase>1</forceUppercase>
                  		<fontPath>./main/fonts/Dosis-Bold.ttf</fontPath>
                  		<fontSize>0.025</fontSize>
                  		<size>0.111 0.015</size>
                  		<alignment>right</alignment>
                  	</text>
                  	<text name="md_developer">
                  		<size>0.187 0.015</size>
                  	</text>
                  	<text name="md_genre, md_players">
                  	</text>
                  	<datetime name="md_releasedate">
                  		<size>0.2 0.015</size>
                  	</datetime>
                  in the oficial theme i have:
                  <text name="md_lbl_rating, md_lbl_releasedate, md_lbl_developer, md_lbl_publisher, md_lbl_genre, md_lbl_players, md_lbl_lastplayed, md_lbl_playcount, md_lbl_favorite">
                  			<color>262626</color>
                  			<fontPath>./data/ubuntu_condensed.ttf</fontPath>
                  			<fontSize>0.03</fontSize>
                  			<size>0.12 0.04</size>
                  		</text>
                  		<text name="md_developer, md_publisher, md_genre, md_players, md_playcount, md_favorite, md_rating">
                  		</text>
                  		<text name="md_description">
                  		</text>
                  		<datetime name="md_releasedate, md_lastplayed">
                  			<size>0 0.04</size>
                  		</datetime>
                  I need to add all these lines ? with md_plashers, publisher, etc ? or only md_favorite and md_lbl_favorite ?
                    @jackalpret you don't must add all fields, but you can.
                    For the favorites tag you only need:
                    md_lbl_favorite and md_favorites
                    Nothing else
                    • jackalpret
                      perfect thanks !
                      i will try later and re-upload the theme when it works 🙂
                        voljega Banned @jackalpret last edited by
                        @jackalpret also your themes files must be in version 4
                        azvarel 1 Reply Last reply Reply Quote 1
                        • azvarel
                          azvarel @voljega last edited by
                          @voljega That's right, I forgot to say
                          • jackalpret
                            I added these lines and doesnt work:
                            	<text name="md_lbl_favorite">
                            	</text>
                            	<text name="md_favorite">
                            	</text>
                            and version 4 in the first lines
                              paradadf Staff @jackalpret last edited by paradadf
                              @jackalpret the first line wirh lbl needs to be on top of everything (for what I can tell). Look sharply and compare. The first line contains many md_lbl_xx, one after another.
                              But I never edited that so I have actually no idea! 😆
                              • jackalpret
                                @paradadf
                                could you correct my lines and reply with the correct order or changes ?
                                thats the content of my xml file:
                                http://pastebin.com/zDF9VWK7
                                  @jackalpret I meant something like this:
                                  http://pastebin.com/dqerkbaA
                                  But there are big chances I'm completely wrong XD
                                  • jackalpret
                                    I brokes the theme 😞
                                      @jackalpret hahahaha sorry!
                                      • jackalpret
                                        @paradadf no problem !
                                        anyone else that can help ?
                                          problem solved ?
                                          • jackalpret
                                            jackalpret Translator @rockaddicted last edited by jackalpret
                                            @rockaddicted said in cant add favorites with controller:
                                            problem solved ?
                                            noup, doesnt work, I cant add the option in xml theme to add favorites with controller 😞
                                            101.0k
