    Urgent/Hurry !!! Emulationstation not launching after brutal power off (removing cord manually)
    urgenthurry launching brutal removing
    4924
    • eightkiller
      eightkiller last edited by
      Hy,
      I got this problem a long time ago but I don't remember what was the solution to this, and I can't find post about it. I'm in a hurry, people are supposed to come and play at home 😢
      I powered off the recalbox by removing cord manually , and now i can't boot anymore in emulationstation (i'm stuck in the black screen with the recalbox logo at the bottom).
      I remember past in the days i had to remove a file or something like this but i can't find which one
      THanks in advance for your help !!!
      • DjLeChuck
        DjLeChuck last edited by
        I'am trying to sumon @Substring or @rockaddicted
        • eightkiller
          Thanks,
          I have in order : Rainbow screen, recovery mode pressing shift screen, black screen with recalbox logo, emulationstation loading screen for a few seconds, then black screen again and it gets stuck here forever.
          eightkiller 1 Reply Last reply Reply Quote 0
          • eightkiller
            eightkiller @eightkiller last edited by
            My bad :'(, I did a full reinstall of recalbox 4.0 , it worked, then i copied my saved files as i always do and the problem shows up again omg, I dont know what's happening
            • DjLeChuck
              Maybe a corrupted file? Try to removed your files and add them incrementally...
              • eightkiller
                D**n, i'll copy the content of files not the file itself, seriously the first day i plan a session with friends, I used recalbox/retropie since 3 years, i modified lots of things, not now 😢
                DjLeChuck 1 Reply Last reply Reply Quote 0
                • DjLeChuck
                  DjLeChuck @eightkiller last edited by DjLeChuck
                  What's your "saved files"? Thousand of files, some config files, all of your /share folder?
                  • eightkiller
                    eightkiller last edited by eightkiller
                    some configfiles (fstab,s92emulation,recalbox.conf,...) , themes files, retroarchconfigfiles, etc...
                    • eightkiller
                      I managed, reinstalled everything and copied properly what i needed to, so problem solved.
                      Yet It would be nice to have clues on what to do except reinstalling everything in case of this kind of problem ?
                      Thanks in advance.
                      • DjLeChuck
                        Maybe have a look in logs: /recalbox/share/system/logs/ and /recalbox/share/system/.emulationstation/es_log.txt
                          paradadf Staff last edited by
                          I'd recommend you to backup your share partition. Actually, te best would be using an external storage device for the share partition. That way is very unlikely that something corrupts it even if you unplug your recalbox like an animal (no offence).
                            corrupted gamelists ?
                            • jsianes
                              jsianes last edited by jsianes
                              I had similar issue and I did a full re-install of Recalbox. I have all my games and configuration in an external WD Element HD connected to the RPI3 via USB. The good thing of this you don't need to mess about moving games and conf to the SD. All the configuration is inside the external HD. So, when reinstalling, you don't need to worry about the SD. Just reinstall and select the external HD as your preferred storage and all your roms and configuration will be there.
