    Exit emulator with one button press vía gpio
    GamePad/GPIO/USB encoder
    9
    41
    21960
    • 8bit_astronaut
      8bit_astronaut last edited by
      Looking in The wiki i found this https://github.com/recalbox/recalbox-os/wiki/Add-a-start-stop-button-to-your-recalbox-(EN)
      A really usefull guide, and at The bottom it says "exit emulator with one gpio button press"
      But when i try to enter to that page, i cant, it sends me directly to The menú and that sucks....
      Any info...please?
        paradadf Staff @8bit_astronaut last edited by paradadf
        @8bit_astronaut I don't know what happened with that page (there was a spanish version too).
        But the creator of that script is @Phantis, so maybe he can clear things out.
        Edit: Hmmm, can't find him anymore.
        Update: @Bug why did you erase everything? You even changed your username!
        DjLeChuck 1 Reply Last reply Reply Quote 0
        • DjLeChuck
          DjLeChuck @paradadf last edited by
          @paradadf Nevermind, thanks Google Cache @8bit_astronaut : http://webcache.googleusercontent.com/search?q=cache:https://github.com/recalbox/recalbox-os/wiki/Enable-Gpio-button-to-close-emulator-with-only-one-button-press
            paradadf Staff @DjLeChuck last edited by
            @DjLeChuck wow, didn't know about that. Can you also access the links for the scripts itself on that page?
            • DjLeChuck
              @paradadf Sadly no, that's what I just see 😞
              • DjLeChuck
                DjLeChuck @DjLeChuck last edited by
                Page restored: https://github.com/recalbox/recalbox-os/wiki/Enable-Gpio-button-to-close-emulator-with-only-one-button-press
                But scripts are always missing...
                • 8bit_astronaut
                  So....now we cant use that script?
                  Gosh thats terrible....
                  • DjLeChuck
                    DjLeChuck @8bit_astronaut last edited by
                    @8bit_astronaut The terrible thing is that " @Bug " @Phantiss has closed his account and delete everything without any reason! ><
                    • 8bit_astronaut
                      Thats even worst....
                      • 8bit_astronaut
                        Any alternative to that script....?
                          voljega Banned @DjLeChuck last edited by voljega
                          @DjLeChuck maybe @substring has still the scripts somewhere because I kinda remember to have read in a thread he tested it
                            paradadf Staff last edited by
                            I would rather ask @supernature2k, as he told me he was creating his own script to do that.
                            • 8bit_astronaut
                              Thank you! A lot of people would use it
                                @supernature2k I SUMMON YOU !!!
                                supernature2k 1 Reply Last reply Reply Quote 0
                                • supernature2k
                                  supernature2k @Substring last edited by
                                  @Substring Yep, how can I help?
                                    Substring @supernature2k last edited by
                                    @supernature2k where is your fringing script to kill emulators via GPIO ?
                                    • supernature2k
                                      supernature2k @Substring last edited by supernature2k
                                      @Substring try this:
                                      import RPi.GPIO as GPIO
                                      import time
                                      import os
                                      import thread
                                      import datetime
                                      import socket
                                      import sys
                                      from datetime import datetime
                                      from configgen import recalboxFiles
                                      # this last one retrieves emulators bin names
                                      IPADDR = "127.0.0.1"
                                      PORTNUM = 55355
                                      # IP and port for retroarch network commands
                                      QUIT = 3
                                      GPIO.setwarnings(False)		# no warnings
                                      GPIO.setmode(GPIO.BCM)		# set up BCM GPIO numbering
                                      GPIO.setup(QUIT, GPIO.IN, pull_up_down=GPIO.PUD_UP)
                                      # GPIO on pin 3 is the GPIO 2 in BCM mode
                                      #to Reset+
                                      # Define a threaded callback function to run in another thread when events are detected
                                      def button_pressed(channel):
                                      	nwcommand="QUIT"
                                      	retroarch(nwcommand)
                                      	killthats&ast;&ast;t(channel)
                                      #	on quit press, trying to kill all listed emus
                                      def killthats&ast;&ast;t(channel):
                                      	if channel == QUIT:
                                      		for bin in recalboxFiles.recalboxBins:
                                      				print bin
                                      				proc = os.path.basename(bin)
                                      				print proc
                                      				os.system("killall -9 "+proc)
                                      # 	sending network command to retroarch (only exit and reset atm)
                                      def retroarch(nwcommand):
                                      	try:
                                      		s = socket.socket(socket.AF_INET, socket.SOCK_DGRAM)
                                      	except socket.error:
                                      		print 'Failed to create socket'
                                      		sys.exit()
                                      	s.sendto(nwcommand, (IPADDR, PORTNUM))
                                      GPIO.add_event_detect(QUIT, GPIO.BOTH, callback=button_pressed, bouncetime=2)
                                      while True:
                                      	time.sleep(0.2)
                                      sevenx 1 Reply Last reply Reply Quote 0
                                      • sevenx
                                        sevenx @supernature2k last edited by
                                        @supernature2k
                                        Does this automaticly start ES again after killing the Emulator?
                                        • supernature2k
                                          supernature2k @sevenx last edited by
                                          @sevenx no as ES is not killed when you launch an emu
                                          • sevenx
                                            @supernature2k
                                            Do you have some time, to talk about a new project from me? Over PM?
