    Solved Where is es_system.cfg?
    where essystem.cfg
    5742
    • gotogooch
      gotogooch last edited by gotogooch
      I've expose hidden files and folder and opened /recalbox/share/system/.emulationstation but it is nowhere to be found. All that's there is es_input.cfg, es_log.txt, and es_settings.cfg.
      I've seen some file paths contain share_init da heck is that?
      • DjLeChuck
        DjLeChuck last edited by
        Yep you're right, it's in share_init : /recalbox/share_init/system/.emulationstation/es_systems.cfg
        gotogooch 1 Reply Last reply Reply Quote 0
        • gotogooch
          gotogooch @DjLeChuck last edited by
          @DjLeChuck Thank you, but how the heck do I find share_init?
          All I can see is share.
          • DjLeChuck
            It's only accessible through SSH, not with your file explorer.
            And you must change write permissions on partition / ( mount -o remount, rw /)
              paradadf Staff last edited by
              You can use WinSCP too.
              • gotogooch
                I'm trying to make a backup of es_system.cfg so that I can make a folder that uses the Sega Genesis theme and another that uses the Japanese Mega Drive theme and the same for Super Nintendo/Super Famicom per Nachtarm's instructions here: https://github.com/recalbox/recalbox-themes/issues/131
                Is there a guide somewhere on how to do this?
                • DjLeChuck
                  DjLeChuck last edited by DjLeChuck
                  Maybe this: https://github.com/recalbox/recalbox-os/wiki/Network-access-with-WinSCP-(EN)
                  or this if you prefer command line: https://github.com/recalbox/recalbox-os/wiki/Root-access-on-terminal-(EN)
                    I've seen different threads where people have done that. Use the search function and you'll find it.
                    Nachtgarm didn't give any instructions, it was just an idea.
