    Lunar Lander, cannot insert coin
    Emulator Arcade/PC/Console
    lunar lander cannot insert coin
    • gavsta
      gavsta last edited by
      Hi,
      I am running a new fresh install of Recalbox on an RPi3.
      Its enclosed in Picade, but also has a USB keyboard attached.
      For the life of me I cannot get Lunar Lander to accept a coin to play, it loads just fine though.
      No key input variations work at all.
      Any ideas?
      Gavsta.
        paradadf Staff last edited by paradadf
        What Emu? That just happens with some games.
        gavsta 1 Reply Last reply Reply Quote 0
        • gavsta
          gavsta @paradadf last edited by
          @paradadf I think there is two on the default install of Recalbox, and it does the same on both.
            paradadf Staff @gavsta last edited by
            @gavsta depending on the romset you use, you put your roms in different folders. On different folders, the cores are also different. You must specify exactly which romset you are using and in what folder you are putting the rom, plus any relevant modification you might have done. Wirh incomplete info we can't help. Read the arcade wiki if you don't know what I'm talking about.
            101.0k
