    Setting up N64 controls
    Emulator Arcade/PC/Console
    setting controls
    • probotector
      probotector last edited by
      Hi all, I'm running Recalbox 4.0.0. I'm using a PS3 controller. For some reason I am unable to call Retroarch with Hotkey+b so I can't modify controls mapping. Is there soemthing I am missing? Thanks in advance for your help.
        paradadf Staff last edited by paradadf
        Mupen64Plus is used in its standalone version, therefore no retroarch menu.
        Take a look at the following post for info about setting up your n64 controller:
        https://forum.recalbox.com/topic/5123/n64-controller
        • probotector
          Hi! Thank you for your answer. Is there a way to modify controls in Mupen64Plus? Thanks for your help!
            I already gave you a link to another thread where that has been explained.
            100.8k
