    exit button in controller without hotkey ?
    GamePad/GPIO/USB encoder
    button hotkey
    39414
    • jackalpret
      jackalpret Translator last edited by
      Hi, there are any way to configure 1 button to close/exit during play ?
      without using hotkey + b combination ...
      best regards !
        voljega Banned @jackalpret last edited by
        @jackalpret hotkey+b isn't used for exit, hotkey + start is, you must have misconfigured your pad. and no there is no way to have only one button to exit an emulator and it's good because you would exit emulators by mistake... if you have a keyboard you can use esc though
        jackalpret 1 Reply Last reply Reply Quote 0
        • jackalpret
          jackalpret Translator @voljega last edited by
          @voljega yeah, but in bartop for example, for some others frontends you can have 1 dedicated button to exit game
            @jackalpret not for recalbox sorry
            jackalpret 1 Reply Last reply Reply Quote 1
            • jackalpret
              @voljega thank you !!
                Substring @jackalpret last edited by
                @jackalpret we have something that should be available with 4.1 to stop emulators with a GPIO button. @supernature2k can tell you more
                Marcelo Souza lainbebop 2 Replies Last reply Reply Quote 0
                • Marcelo Souza
                  Marcelo Souza @Substring last edited by
                  @substring said in exit button in controller without hotkey ?:
                  That would be amazing. Specially for CaseMod projects. I want to use the Case buttons for reset and Eject roms... (SNES). Using GPIO buttons. But it seems impossible since it only accepts special commands on 1P controller. 😞
                  • lainbebop
                    lainbebop @Substring last edited by lainbebop
                    deleted!
                    Bartop Metal Slug Home Made :)
                    https://forum.recalbox.com/topic/7656/my-mini-bartop-metal-slug/
