    Problem Direction pad N64 emulator
    GamePad/GPIO/USB encoder
    direction pad
    6182
    • sanchez89
      sanchez89 last edited by
      Hello!
      First say I tried to see one similar post before oppening this one, but i did not see one, escuse me if there is one similar.
      My problem is I can not play n64 games because the Direction bottoms (up, left, right...) do not work. Only in N64 emulator, with the rest of them I do not have any problem.
      I am playing with a ps2 controller with a usb adaptor.
      I do not know how to short it out.
      Thank you ever so much for all your answers.
      Regards
        paradadf Staff @sanchez89 last edited by
        @sanchez89 have you tried using the analog stick? n64 controllers had one, so normally you played with it.
        • rossieric
          rossieric last edited by rossieric
          Hello everybody,
          I'm totally new here.
          I'm using ps3 dual-shock controller (bluethoot). They work great for me.
          But I have an issue with the directional pad on Mariokart N64 game.
          On this specific game the analog stick work, but not the directional pad. I can't get used to it.
          On other N64 games or other system the both (dpad + analog Stick) work great !
          Is there someone with the same issue or, even better, with a solution.
          Thank's for every tip !
          Best R.
            Substring @rossieric last edited by
            @rossieric Maybe the game didn't allow the use of the DPad ?
            rossieric 1 Reply Last reply Reply Quote 0
            • rossieric
              rossieric @Substring last edited by
              @Substring Thank you,
              Maybe, but with other controller (usb snes cheap copy) where there is only d'pad it work !
              paradadf Substring 2 Replies Last reply Reply Quote 0
                paradadf Staff @rossieric last edited by
                @rossieric @Substring Almost any n64 game allowed you to play with the D-pad. Some would be functional on menus, but not always.
                About your SNES Pad... That's because of the magic of configgen 😉
                If you don't map any analog stick, it will use the D-Pad instead of the analog. But that is an exception!
                  @rossieric then indeed, sthg is wierd here
                  • rossieric
                    rossieric @paradadf last edited by
                    @paradadf @Substring
                    THANK YOU for your help. So for the moment I'll keep on with the analog.
                    If I really can't get used to it i will remap the controller (skipping the analog) when I play Mariokart 🙂
                      @rossieric Can you https://github.com/recalbox/recalbox-os/wiki/Recalbox-support-(EN) ? I guess there is a hole in configgen for your case, i'dl like to solve it if I can
                      • rossieric
                        @Substring Hi again, here is the file you ask me for http://onlinexpo.ch/recalbox-support-20170115003420.tar.gz
                        At least i guess it worked !?
                        Thank'S
                          @rossieric it did work 🙂
                          But as paradadf explained : you can't compare two pads that don't have the same format as they are mapped in a different way for N64. And it really looks like MK64 doesn't let you play with the real dpad on a N64 pad. So nothing is wrong here
                          • rossieric
                            @Substring OK thank you !! I understand.
                            I think I sent you the file ehn the controller was mapped without the analog stick ( i did skip it in the configuration page ) are you interested in a new one ?
                              @rossieric looks like one of your pad has a weird name like "HID blablabla" right ?
                              • rossieric
                                @Substring I dont know ? i didn't rename them ! On the recalbox controller settings menu they are called something like usb.... (cable) and playstation... (bluethoot)
                                  @rossieric anyway just tried mariokart : it won't let you play with the dpad. So that's set ingame
