    DOS in recalbox 4.1 doesn't work, is there a log to see the error?
    Emulator Arcade/PC/Console
    dos recalbox 4.1 doesnt log
    6
    11
    6876
    • Jesús BL
      Jesús BL last edited by Jesús BL
      I'm trying to run DOS games in the new recalbox 4.1 (unstable-build-45) in my raspberry pi 2, but they doesn't start and I return to the main screen.
      I see in the Boad Compatibility that it may be run, but I search a log to see where the error is without success.
      I see all the log files in /recalbox/share/system/logs, are there more paths?
      Trucos y recetas para raspberry pi:
      http://malagaoriginal.blogspot.com.es/search/label/raspberry pi
      Substring Tornelf 2 Replies Last reply Reply Quote 0
        Substring @Jesús BL last edited by
        @Jesús-BL have you read the embedded readme file in the roms dir ?
        Jesús BL 1 Reply Last reply Reply Quote 0
        • Jesús BL
          Jesús BL @Substring last edited by
          @Substring Yes, I change the dir and I include .pc at the end of the name.
          Also I add dosbox.bat files with the name of the file to execute.
          I try with some champ games and mach3
          • sdlvivian
            sdlvivian last edited by
            I am also having this exact problem. The dos box logo does display small in the top left corner of the screen before exiting back to emulation station. I've tried this with 10 plus games from different sites.
              before play game you need may be to install it
              you need to add install.exe or setup.exe in your dosbox.bat
              • Tornelf
                Tornelf @Jesús BL last edited by
                @Jesús-BL You have to call the file "dosbox.bat" with small letters, not DOSBOX.BAT.
                Raspberry 4
                ODROID XU 4 avec ventilo bruyant
                Microsoft xbox 360 wireless pad
                Clavier Logitech k400
                RECALBOX 7.2
                • simba51
                  simba51 last edited by
                  In "dosbox.bat", you must put:
                  cd 😄
                  xxx.exe
                  xxx being the name of your executable back
                  Cartes RPi Zéro 2 W - RPi Zéro W - RPi400 - RPi 4/4Gb - RPi 3b - RPi 3b+ - RPi 3 a+
                  Stockage 16Gb Sandisk, 32Gb Samsung et clé usb 64Gb & 128Gb
                  2 manettes PS3 Freegun Bluetooth - 2 manettes 8BitDo SF30 Pro Bluetooth
                  • simba51
                    cd 😄
                    xxx.exe
                    • sdlvivian
                      I made the changes to the .bat file.
                      cd 😄
                      Install.exe
                      blood.exe
                      It still responds the same. I tried it on solar winds which just has a solar.exe and no install.exe and it behaves the same. Thanks for everyone's help. Do I need to have more in the bat file? Other sites talk of mounting drives. I don't know if that applies to recalbox. Could it be a resolution problem? I've seen similar behaviour when my n64 and dreamcast emulator weren't set to the proper resolution. Also when I didn't have the correct bios but as far as I know dosbox doesn't have a bios. My msx did something similar before I got the proper data files. Thanks 😉
                        I download Solar Winds version dos.
                        You need to create solar-winds.pc folder.
                        create dosbat.bat with only :
                        solar2.exe
                        solar-windows.pc
                        bh_char.dat
                        bh_conv.dat
                        bh_epal.dat
                        bh_epic.dat
                        bh_expl.dat
                        bh_hype.dat
                        bh_imp.dat
                        bh_mis.dat
                        bh_mp1.dat
                        bh_ms.dat
                        bh_mu1.dat
                        bh_mu10.dat
                        bh_mu11.dat
                        bh_mu12.dat
                        bh_mu13.dat
                        bh_mu2.dat
                        bh_mu3.dat
                        bh_mu4.dat
                        bh_mu5.dat
                        bh_mu6.dat
                        bh_mu7.dat
                        bh_mu8.dat
                        bh_mu9.dat
                        bh_mw1a.dat
                        bh_obj.dat
                        bh_pal.dat
                        bh_pan.dat
                        bh_peop.dat
                        bh_pic.dat
                        bh_plan.dat
                        bh_seq.dat
                        bh_seq2.dat
                        bh_seq2b.dat
                        bh_shd.dat
                        bh_ship.dat
                        bh_sml.dat
                        bh_start.dat
                        bh_title.dat
                        bh_v1.dat
                        bh_v2.dat
                        bh_v3.dat
                        bh_v4.dat
                        bh_v5.dat
                        bh_v6.dat
                        bh_v7.dat
                        bh_vfd.dat
                        bh_wr.dat
                        config.dat
                        dosbox.bat
                        helpme.doc
                        hsav01.dat
                        license.doc
                        list.txt
                        order-uk.doc
                        order.doc
                        page.dat
                        savlst.dat
                        solar2.exe
                        It's work for me with a keyboard to play game.
                        • Jesús BL
                          I update to a newer version of recalbox 4.1 and now the DOS games runs OK!
