    Solved Modifying the first screen. Ive tried all
    Themes & Interface
    modifying screen ive tried
    6
    11
    7425
    • dormonid
      dormonid last edited by
      Hi everyone. I just read the tutorial session and coudnt find any tutorials on how to modify the first screen and the menu screens of the Emulation Station.
      Turns out that I has having huge compatibility problems and coudnt get all the box covers by scrapping directly from the raspberry pi, so I downloaded a full image from the web. The image came complete but they have a custom screen (one of the first screens) with their brand or the store´s brand and I would like to restore it all to the original theme. I downloaded the original theme, but even modifying it from the menu, the first screen doesnt change and so the menu (bottom right corner). What should I do?
      Thanks in advance
        paradadf Staff last edited by
        Did you buy recalbox somewhere?
        dormonid 1 Reply Last reply Reply Quote 0
        • Nachtgarm
          Nachtgarm last edited by
          Can you provide some screenshots, please?
          • ian57
            ian57 Staff last edited by
            You can't modify the first of ES in a simple way. This screen is part of the exe and you'll need to recompile ES to change the splash of ES.
            • dormonid
              dormonid @paradadf last edited by
              @paradadf @Nachtgarm No I didnt buy the recalbox ffrom anyone. but I bought an image full of roms and already scraped. I tried everything but failed to scrap decently. the scrapper to do on PC isnt user friendly and so... I bought this image, put it on the SD card using imgUSB and now when I boot it, the very first screen is a screen with the brand of the store or something like that, then the image switchs to ES screen and then it boots to the menu. Im ok with the ES screen (white with ES logo in blue). im not ok though with the first screen.... and its the same screen that appers when you launch a heavy game. it stays on this screen till the game is loaded.
              • ian57
                "No I didnt buy the recalbox ffrom anyone. but I bought an image full of roms and already scraped." So you bought it ! you've been screwed up... recalbox is free 😉 " the very first screen is a screen with the brand of the store" !!!! please give screenshot !
                • supernature2k
                  supernature2k last edited by
                  Yes please give us some screenshots, strange story you're telling us!
                  • dormonid
                    @Nachtgarm I will record the boot of this and will put on youtube. I will put the link for you guys
                    Here´s the boot recorded. I have terrible english so sorry about that. First screen is the original one, then it comes the one I want to restore to original, then after I start a game that screen appears again!
                    Not to mention they put "hercules games" on the console select menu too on the botton right! d**n this guys!
                    https://www.youtube.com/watch?v=Pu169AA06qM
                    • Nachtgarm
                      Nachtgarm @dormonid last edited by
                      @dormonid You have been scammed! What you have there is not an official distribution of recalbox, but a rip off product by the company Hercules Games from Brazil.
                      BUT, it looks like that they "just" put their own logo into /recalbox/system/resources/splash/, which is a read-only directory by default.
                      I would suggest that you download the official version of recalbox here: https://github.com/recalbox/recalbox-os/releases
                      and reinstall it to your SD card.
                      If you don't want to use that, you should get read/write access to your system partition (read the Wiki) and replace the picture with the default one, which can be found HERE
                      • dormonid
                        dormonid @Nachtgarm last edited by
                        @Nachtgarm D**n these b*****ds! Thanks for your help! I will do a fresh install!
                          Substring @dormonid last edited by
                          @dormonid or maybe just force an update
