    exFat Support for external HDD
    exfat external hdd
    4727
    • Camillo Melanzane
      Camillo Melanzane last edited by
      Will there be exFat support for external HDD in the future?
        Substring @Camillo Melanzane last edited by
        @Camillo-Melanzane maybe, i think there is not much work to do for that. Have you tried an exfat disk ?
        • Camillo Melanzane
          @Substring. Yes, I use a 2TB external drive. It does work with NTFS and Ext4, but it doesn't work with exFat. Unfortunately I am on Mac which doesn't support NTFS and Ext4.
            @Camillo-Melanzane You can still use Fat32 🙂
              paradadf Staff last edited by
              exFAT will be supported on 4.1 (already implemented).
              • ian57
                ian57 Staff last edited by
                @Camillo-Melanzane use a real linux system to get the full support of all filesystems 😉
                • Camillo Melanzane
                  Thank you guys! In this case I'll wait for the first 4.1 betas 🙂
                  Fat32 does not allow files larger than 4GB. I also use Kodi for streaming.
