    Solved recalbox external startscript do not start
    recalbox external startscript start
    3223
    • rapid
      rapid last edited by
      Hello,
      I try to execute an external startscript.
      What I tried is to edit
      nano /recalbox/share/system/custom.sh
      and place there my script.
      If I execute ./custom.sh in shell it starts and I see the proceses in "top"
      and the script works. After rebooting I can't see the proceses in "top"
      I tried to switch order in /etc/init.d and move S99custom to S31custom or S04 custom
      but after reboot nothing happens. If I execute ./S04custom manually it starts and all looks good.
      Places I already checked while trying to solve my problem
      https://github.com/recalbox/recalbox-os/wiki/Add-your-own-startup-script-(EN)
      https://forum.recalbox.com/topic/4370/help-with-starting-an-automatic-script-on-start-up
      but didn't work for me.
      Why is my startscript not executing on start?
      Any idears?
        chmod u+x ~/custom.sh?
        • rapid
          ~/custom.sh is set to 755 owner avahi:root
          the script in custom.sh is following:
          #!/bin/sh
          #/recalbox/share/system/custom.sh
          cd
          cd StromPi2
          python powershutdown.py &
          python poweralarm.py &
          The rest of this works if I start it manually. The reason for this is that this way I could turn of my physical power switch and my pi shutdown with a little battery himself. 😉
          I'll keep on searching and hope I will get it to work but thx @Substring
            Substring @rapid last edited by
            @rapid chown root ~/custom.sh because i don't see any reason why any script should belong to avahi
            Don't cd in a init script, you should be explicit on the path because $HOME can be unset at init. So just cd is probably in /usr/bin, you'd better cd /recalbox/share/system/StormPi2
            • rapid
              Ok. Shame on me 😄
              To make a long storry short.
              This works. Thx a lot. @Substring 😉
              It's been a while since I made scripts, so I just tried it the "old dos" way...
              So it's solved (still searching the button for solved)
              • Andrei
                Andrei last edited by
                i know this post is old but i was looking for this to run my LED buttons when PI is booting. Finally i managed to get it working
                I copy the script file in "/recalbox/share/system" then i fallow Substring recommendation
                my custom scrypt is looking like this:
                #!/bin/sh
                python relay1.py&
