    Help with starting an automatic script on start up
    help starting automatic script start
    • blackmagik
      blackmagik last edited by blackmagik
      I am looking to have a certain command start when i boot up my rasberry pi. This is to fix the xbox 360 blinking light problem. I found this is the only solution that works.
      xboxdrv --detach-kernel-driver --trigger-as-button --wid 0 --led 2 --deadzone 4000 --silent & sleep 1
      However, upon restart its back to acting up. I tried following https://github.com/recalbox/recalbox-os/wiki/Add-your-own-startup-script-(EN)
      but i got lost at :::copy S02serial to your new script ::: When i try to write to it it keeps telling me its read only file system
      Any help would be amazing!!
      mattrix 1 Reply Last reply Reply Quote 0
        why don't you enable the xboxdrv in the recalbox.conf ?
        • mattrix
          mattrix @blackmagik last edited by
          @blackmagik
          Create below file and put in your command
          /recalbox/share/system/custom.sh
          Make it executable
          chmod +x custom.sh
          /recalbox/share/system/custom.sh (if exists) is ran at boot.
